Question about Kenmore Refrigerators
Side by side refrigerator model # 51562103 center wall - very hot
Center wall (when you open door) freezer & refrigerator temperatures seem to be normal.
    President:
  • 1,462 Answers
If fridge and freezer temps are normal, what on earth is your problem?
Posted on Nov 14, 2008
Kenmore elite refrigerator
where is the ice,is it on the food and shelves or is it on the back inside wall of the freezer?if it's on the back inside wall of the freezer you have a defrost problem,bad defrost thermostat,heater,timer or board depending on your model number,if it's on the shelves,door and food packages warm air is getting into the freezer somehow either from the door not closing or the door was left open,could have a bad gasket on the door,the ice chute door could be broke and not closing.let me know what you find and the picture shows a side by side but i'll need the model number too,if it's a side by side or freezer on the bottom the model number should be in the fridge section,on the right hand wall up near the ceiling,if the freezer is on top the number should be on the left side wall in the fridge section up near the ceiling.but with this hot wheather we're having if the door was left open this will happen,you can shut down the machine or unplug it,remove the food from the freezer and melt the ice with a hair dryer,don't do this with the machine running because the hot air will cause the same problem,after the ice is melted you can put the food back in and restart it.
Jul 20, 2013 | Refrigerators
Freezer not working, fridge is fine.
That seem to me like it could bea simple cleaning. Dust and junk gets into the condenser. Blow that ****** out and party on. I have your models service manual on my foggy blog
Mar 05, 2012 | GE GSS25LGM Side by Side Refrigerator
My refrigerator side is not maintaining a cool temperature, and the green temperature light is off (the freezer side works fine)
the problem is in the freezer side,all it does is blow clod air from the freezer to the fridge side so if the fridge is warm the freezer side is either iced up or the fan isn't blowing,open the freezer door,do you hear the fan blowing,if not you could have a bad evap fan motor,also check the back inside wall of the freezer,you might have to pull the second from the bottom bin out and touch the wall and see if it's iced up or if there's frost on it,if so you have a defrost problem,let me know what you find and send the model number ,open the fridge door,on the right side up near the ceiling you'll see a tag with the model and serial number,i just need the model number and i'll be glad to help you
Oct 31, 2010 | Kenmore 57066 Side by Side Refrigerator
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
Center support of Side By Side is Hot to the touch
Hi, welcome to Fixya. The heat between the doors is normal and done by design to help prevent moisture along the "breaker strip"/divider. If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about. Just be sure the condensor fan isn't jammed and still turning. If not turning it can cause the unit to become extremely hot. The amount of heat can and is determined by several factor's such as, temperature setting - lower/colder the temperature is set the more the run time the hotter the strip. The ambient temperature - hotter the environment the more the unit runs the hotter the strip. The amount of "fresh" content added to the unit - new items add a lot of warmth thus demanding the unit to run more to remove this heat causing the strip to be hotter. Build up of dust & dirt on the condensor coils ( they should be vacuumed annually ) - this also causes the unit to run excessively which in turn makes for more heat on this strip. These are all things which can and do determine the amount of heat between the doors. If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned. Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward. Please take a second to rate the info provided here. Macmarkus :)
Jun 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a bottom freezer french door mode. The
remove both crisper pans and check the return are duct opennings. next check if there's a built up frost/ice on the rear wall of the frzr. is you frzr fan blowing air? if so, there's a small window inside the refrig's freshfood side back wall towards the cieling, make sure that's open.the cover should snap off. if window/damper is open, go ahead an pour hot water down the return air ducts behind the crisper pans. they look like grill slots in one or both coners
Jul 14, 2009 | Maytag MFI2568AE Side by Side French Door...
Freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Oct 27, 2007 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
251 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
