My chrysler pacifica dvd player is not working. I get 3 flashing lights, alternating with 3 other flashing lights. I also get an error message.
  • 3 more comments
  • p_schoonover Nov 24, 2008
    I have exactly the same problem. 3 alternating flashing lights and an error message
  • dosborne13 Dec 21, 2008
    I don't get the alternating flashing lights but get the error message; my husband took the dashboard apart and still couldn't get it working.
  • robhaas Dec 29, 2008
    I just got this same problem yesterday! Eject sequence oprerates but nothing else - only flashing lights
  • Anonymous Feb 23, 2009
    I get the 3 flashing lights alternating and a disk error message.
  • fkiene Apr 14, 2009
    My DVD Player has been trouble since I purchased my 2004 Pacifica.
    At times it locks CD's and will not eject them, I have had the flashing lights three at a time then they alternate. I just had the dealer put a brand new one in and in less than a week I get Error whike playing CD's.
Had the same problem, took my Pacifica to the dealer where they diagnosed an internal mechanical malfuntion. They said the only way to fix it is to rebuild the unit. Luckily I bought the 7 year 100 thousand mile warranty and didn't have to pay the estimated $700.00 parts and labor charge. It is fixed and works just fine.
Posted on Jan 12, 2009
Hi 2004 Chrysler Pacifica p2066 p0404 Also it drain the battery when not in use
P2066 relates to a fuel sensor level:
chrysler error code p2066 Google Search
P0404 relates to an EGR fault (Exhaust gas Recycler). You may be able to clean the EGR:
Whether this is causing your battery to drain isn't clear - there are other causes of batteries discharging, such as burnt out diodes in the alternator.
Treat it as 3 faults - try and rectify the 2 error codes first (disconnect the car battery whe not in use to prevent it draining) .. and then look at the cause of the battery discharge
Mar 11, 2017 | 2004 Chrysler Pacifica
The dvd player won't work. The 6 lights are blinking on and off. How do I fix this
Happened to me as well. I first had it give me an error with disk 6 flashing so I removed it, put it back in and the lights would flash from 3 left to 3 right. I removed the DVD changer from the car again, removed the top (one screw), removed the black face plate (4 screws and carfully pry up on the bottom tabs when pulling it forward. I then took out the five screws holding the changer (four on top, one in the back) and removed the changer so I could get to the bottom. There is a set of wheels on the bottom that I started to turn which was easy at first but it seemed to reach a point where it was stuck so I gave it a bit more and something seemed to snap into position. So I assume that it was just the mechanism that jammed when it tried to switch disks. I put it back together, installed it, and it works fine now. When it first started all the lights would flash but then it settled down to a single light and I ejected the first 3 disks and number 6 and let it play the forth. Now to see how long it lasts.
Jun 08, 2015 | 2005 Chrysler Pacifica
2006 Pacifica dashboard lights faintly flicker and ABS light flashes and dings
Accident damage ... may be a coincidence. Check the ODB error messages.
Sep 30, 2017 | 2006 Chrysler Pacifica Touring
2004 Chrysler pacifica DVD player problem
the dvd on a 2004 chrysler pacifica doesnt start you can hear the sound but no picture. what could be the problem?
Nov 20, 2008 | 2004 Chrysler Pacifica
Televison & Video Logo
2,442 people viewed this question
Top Televison & Video Experts
