Question about Philips 9P6031C 60" Rear Projection Television
Philips 9p6031c no pic. no sound just green light on!!!!!!!!!!!
Model 9p6031 c102 power on and only the green light on the front is on it only blinks when i try to change vol or channels no sound no pic. !!!!had everything checked ( non hot) and he said it is ok put it all back in the set ??????????? i think it did it once before and wife fixed it!!!! but she is now gone. help would be great i can not afford another. Thanks for any help!!!
  • dan harvey Dec 02, 2006
    still need help!!!!!!!!! Thanks
  • Philips Master
  • 3,459 Answers
IC Chip went out. Check www.magnavoxhelp.com for a repair kit
Posted on Jul 05, 2008
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
55'' philips rear projection turns on no video/audio. 9p5544c102
Try removing the two convergence chips from the board - then see if the TV powers on and lights up. If so you narrowed it down. If not - you have eliminated convergence IC problems.
Nov 04, 2009 | Televison & Video
Magnavox Philips 60" 9p6031 c103
deflection problem very common on that model. You can get a new LSB board at the following link, leave them a email and they will respond quickly with a price quote for the LSB if they dont have it listed already, they are cheaper than anywhere else for replacement boards for phillips, RCA and GE. Heres the link.
http://servicemanuals.vstore.ca/
Jan 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
I need help finding a protective screen for a philips 9P6031C 60inch rear projection tv
I may salvage the parts from my set if I cant fix my problem for a reasonable price. I have a projection screen for the 9P6031C, that I may sale if I cant fix the convergence on my set. The screen is in mint condition.
Aug 06, 2008 | Philips 9P6031C 60" Rear Projection...
No Sound & No Picture
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Sep 21, 2007 | Philips 9P6031C 60" Rear Projection...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Green light on the front that is it!!! no sound no pic.
Dec 02, 2006 | Philips 9P6031C 60" Rear Projection...
9p6040 c102 60" television - has power, no sound or picture
Screen shrinks and expands and wams up after 10-20 minutes and then went out completely? Power light still comes on and remote still works? This is a common problem for this model and is most likely related to a bad chip. A tech will charge you over $300.00 to fix it but you can buy the repair kit including the chip, step by step instructions and repair manuals for under $40.00 if you are willing to do a little soldering. Go to http://www.magnavoxhelp.com/ and enter your model or chasis number and order the kit. This will not fix color problems!
Sep 20, 2006 | Philips 9P6040C 60" Rear Projection...
Philips 9P6031C 60" Rear Projection Television Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
