I am not able to reset the passcode.I dont know the passode.I am trying 654321,54321,4321,321. Master code tried 123456,12345,1234,123.Its continously saying Please disarm first enter your access code.
Comments:
Nov 20, 2008
- Thanks for typing..This factory default number(1234) i tried many times after removing the battery and shut it off for several days..When i switch it ON its asking to enter id ..I think i have to replace the master panel now.Do you have any more experience in this case?
It's been several days, so I assume you've done something to stop it all...
If you've not ripped it off the wall, the other thing to stop it completely is to shut it off (i.e. power down). If that's the case, the should default to 1234 after being powered down for several hours. Try 1234 again.
If your problem ain't fixed and the system is not in the trashcan yet, try this: Open panel and enter Utility access code (654321 / 54321 / 4321 / 321), mostly it's 4321, unless someone changed the code. Unplug from powersource and unplug battery.
Now comes the fun part....
Press Cancel + Clock set + Minutes+ at the same time and restore the power with the battery. If it says "Hello, System XX OK" you've reset the panel to factory settings and can set up the whole system from the beginning.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE Security Simon 3 Wireless
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I...
(More)
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I can't figure out how to open the control panel. Thanks a lot for the answer, Mike
