MY SCIENTIFIC ATLANTA EXPLORER 8000 DVR IS NOT WORKING. IT SHOWS THE LIST OF MY SHOWS BUT IT SAYS PLAYBACK ERROR. AND IT WONT PLAY BACK THE SHOWS. WHAT DO I DO? IM AN ACTOR AND IM IN THESE SHOWS/ I WANT TO TRANSFER THEM TO A DISK AND SAVE THEM FOREVER BUT THEY WONT PLAY. THANKS ...IM VERY CONCERNED HERE I WILL NEVER SEE THEM AGAIN.
tvtek
  • 1284 Answers
SOURCE: Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Posted on Jan 22, 2008
charcois
  • 763 Answers
SOURCE: SONY DVD/VHS RECRDER
try this one sir
http://archive.tivocommunity.com/tivo-vb/showthread.php?.=.&s=&threadid=141059&.=.
Posted on Sep 10, 2008
  • 3 Answers
SOURCE: I just bought a Samsung
The first step you sohuld take, in my opinion, is to have the cable company come out and test your line levels to make sure there isn't a lossy connection somewhere.
You might also try rebooting your cable box by turning it off, unplugging it for a minute, then plugging it back in.  I have this issue with the same box and I believe the problem may be that the live recording for pausing and rewinding gets bogged down after a certain period of time.  I've had four of these boxes and had this issue with every one of them.  They seem to have a problem when the cable company pushes an update sometimes that corrupts the firmware and causes problems (my fourth box just failed tonight, that makes four failures in about eight months).
Posted on Mar 04, 2009
  • 50 Answers
SOURCE: Please send instructions and codes to set up this unuiversal remote.
http://www.parkwon.com/rcatest/
this is the site for systemlink 3 programming
Posted on Apr 29, 2009
SOURCE: Use Yamaha Remote to Control Scientific Atlanta Explorer 8300
I want to know the same thing.
Posted on Jan 17, 2010
Code for scientific atlanta explorer 4642 HDC
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 27, 2015 | Philips "Prestigo SRU6006 Universal Remote...
Front power indicator blinks, clicking/high pitch sound
  1. This how to is to repair hard drive, software and some firmware issues that can arise on specific cable DVR and DAC and DCT boxes, First instructions are for Scientific Atlanta hardware. Firstly, one should be certain that the cable box has the coax (cable antenna wire) hooked up to the CABLE IN or RF IN on the box itself and be connected to a "hot" outlet - one that you KNOW works. Test it by connecting a TV directly to outlet. If you get a weak signal, the box will too. Digital boxes require a clean SNR. Remove in-line "surge protectors" on the coax. These prevent the signal from being sent by your cable provider to your box.
  2. Scientific Atlanta DVR or High Def boxes:These need to be "booted" or reset when certain errors occur. No audio on certain channels when SAP is NOT set to ON and confounding error codes that one can't seem to get out of. Common yet confounding errors are : No Audio on DVR Playback. No Audio on Certain Various Channels (ruling out SAP which can be enabled through the box, OR the television set itself) there are easy ways to test. If some channels audio is in Spanish when they are normally in English...the obviously you will check SAP first.
  3. Disc errors. On screen error on your TV that says something like..."there are problems with your storage disc.." or upon DVR playback instead of playing your program it loops upon itself and plays nothing.
  4. two different steps to reboot box: Simultaneously press VOL+ VOL- and "INFO" buttons on box itself, not from remote. Box will then display "bOOt" and shut down totally. Do not press ANY buttons or try to power on said box. Wait for the correct time to display on the box. This process can take anytime from 40 seconds to hours, depending on how fast the cable company's servers are responding at that moment and whether or not you have enough of a cable signal to fire up the download process. If you call customer service for your provider if this does not work, most likely a truck roll will be run for a tech to come out to your residence to fix the signal issue.
  5. When the correct time display is on the Scientific Atlanta box, THEN power on box and problems should be solved. An alternate way to reboot box is to simply unplug unit from power supply and replugging it in. Simply powering it on and off with the POWER ON button will not solve anything.
  6. On a Motorola box and/or DVR, the easy VOL+ VOL- and INFO will not work to reboot. Remove AC power plug from wall socket and wait 30 seconds to a minute while box is powered ON. Plug back in to wall socket.Box will "do it's own thing" and power itself on on it's own after the cycle has been successful (30 - 60 seconds) and the box should power itself back to the ON without you doing anything. Time will not display on Motorola"General Instrument boxes unless you set it up to do so in the settings mode.
  7. Common IControl/On Demand errors:
  8. MOTOROLA BOX Error 225 : A billing lock to prevent you from ordering pay per views. If your account is past due, or if you have an order to move to a new address in the service provider's "system", this is a preventive measure to keep customers from loading up tons of expensive pay per views and skipping out. Your cable company cannot over-ride this error. If you are not in above situations, your provider can "up" the limit on the box and clear it so you can order PPV through your remote control.
  9. SCIENTIFIC ATLANTA: for above mentioned error code, your SA box will display not a code but a prompt to contact your provider by telephone. Same issue.
  10. MOTOROLA BOX ERRORS 204...203.. 207..these may be easily solved by simply reseating the coax and then rebooting box.
  11. SCIENTIFIC ATLANTA ERRORS 2207: reboot box. This is a general code meaning the box has lost contact with the server. All of your iControl /On Demand orders come through your local cable head-end's servers. If and when it gets overloaded and times out, error 2207/207 will happen. Most of the time this is temporary. Reboot box, try again in 15-20 minutes.
  12. DVR BOX not displaying/recording/playing items:
  13. Reboot. Good chance of fixing.
  14. If your TV displays "One Moment, Please. Your Channel Should Be Available Shortly..." this is a SIGNAL issue. Reseat the line running from wall to the CABLE/RF IN on the box and at the outlet at wall. If no joy, call cable operator.
Nov 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
I have the vc500 hooked up and the software installed. I can see the video on the computer screen but when I press record, the computer video looks like it is scrambled. How do I correct this?
Just a wild pitch here; is the video fine after its been recorded or does that play scrambled as well? Make sure your equipment is tightly plugged in. Other than that, all I can say is maybe your dvr is obsolete or your computer is too slow.
Sep 19, 2014 | Diamond Multimedia ( VC500) Video Capture
HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Oct 30, 2009 | Toshiba 32AV502R LCD TV
Clicking noise
Is the clicking louder, and faster, the faster you are fast forwarding and rewinding? If so, it's just be the drive reading the video back. Mine is very quiet and I only softly hear it when there is no sound, like when I FF. Can you move the box into an entertainment center, or further away from the TV?
Mar 15, 2009 | Pioneer DVR-107D DVD±RW Burner
From kaboodleent
The objective is to copy/recover the existing movie/video (shows) thatare inside the hard drive of an Atlanta Scientific Explorer 8000Digital Video Recorder (DVR).
This would involve two steps. The electronics part which isnothing more but physically removing the hard drive (HD) from the DVRand the computer part which is transferring the movie/video files fromthe DVR's HD to a temporary holder (a PC's own HD) and eventuallyburning to DVDs.
Electronics:
The cover of the Explorer 8000 must be removed to expose the inside. The inside would look like the image below.
The component inside the yellow circle is the HD. It is normally heldby a couple of screws and electronically attached to the printedcircuit boards by two (2) connectors. The wide flat cable is the IDEdata interface while the yellow/black/black/red is the power. Onceremoved, this HD can then be treated as a very large flash/thumb drivewith the necessary adapter.
Computer:
The HD would look something like the image below. It is an 80Gb IDE drive.
The HD would then have to be connected to an IDE to USB adapter with anexternal power supply, something like the image below. If you willavail of the services of a qualified computer tech, then most likely hehas something like this already.
The DVR's HD can now be attached to an operational computer. Here is the trick, the computer must be running Linux.
Nov 14, 2008 | Oregon Scientific OR-RM313PA ExactSet...
I have an Inovage Jumbo Universal remote that I need to program and believe my wife has tossed the manual. I have a Scientific Atlanta DVR and a Sony TV (just changed tvs as my RCA died; I also added the...
All the jumbos are basically the same. For your RCA TV, I show 000,003,004,005,006,007,019,096,098,099,100,101,102,103,129,179, 181,188,190,196,202,203,215, or 233
For a Scientific Atlanta VCR, I show 006,036, 037, or 038. These codes might work on your DVR as well.
Jul 01, 2017 | Televison & Video
Recording from DVR.
There is a firmware update posted on the Sony support web site. It takes care of the copy protect error. However, i have encountered an error where the recorder doesn't identify the input signal. It posts the message "waiting for input signal." I have no solution for this one yet.
Dec 17, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
