Question about Acer Computers & Internet
The color on my new Acer X193W monitor is that of Safe Mode,but the computer is not running in safe mode. I cant seem to change it to the normal colors.
    Sergeant:
  • 395 Answers
What graphics driver is installed? If it is Microsoft driver you may need to install correct driver. Try Update from Device Manager - Hardware - Display adpater - update driver
Posted on Nov 16, 2008
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Resolution set too high ..no picture cant get safe mode to work up down arrow buttons wont move ..computer wants to start normal...cant get into computer with no monitor display ...help...brand new...
Sounds like you need to boot up in VGA mode instead of Safe Mode
Step 1. Power Down your computer.
Step 2. Powwer on your computer and press F8 to enter Safe Mode
Step 3. Instead of selecting Safe Mode, Select VGA mode.
Step 4. Once in Windows, uninstall your graphics card for your Monitor.
Step 5. Restart your machine, when you log back in Windows will reinstall the drivers for your monitor.
Apr 21, 2010 | ViewSonic VX2025wm 20.1" LCD Monitor
Signal over range.
Could be a driver issue with your monitor. Safe mode bypasses them with working defaults.
Aug 31, 2017 | Acer X193W LCD Monitor
Hi. when i set my acer x193w monitor to 1440 x 900 resolution, the display becomes scarmbled. please help. thanks
One option you have is to go to safe mode and uninstall video driver in device manager and reboot your pc and it will detect it by it self and put it in right resolution. It is possible that drivers were corrupted if it got scrambled, also make sure it can support it. Best place to get drivers would manufacturer site not via update driver button. To get to safe mode you need to shut down your pc and press power to turn it back and and once this is done keep on tapping F8 key until you get Advanced Startup Menu. From here just choose safe mode and follow prompts. Once in safe mode right click on my computer and click manage option.On left side of new window click on Device Manager and locate driver for display. Right click on it and click uninstall and follow prompts. Once done reboot and should be all set. Good luck
Dec 31, 2009 | Acer X193W LCD Monitor
The resolution comes and goes...
For that when you power up the computer press F8 key then enter in safe mode.
Then uninstall graphic driver then start it in normal mode then install graphic driver again then it wroks fine.
Let me know if you need more assistance.
Thanks.
Oct 05, 2009 | Acer X193W LCD Monitor
How to change resulution when you get input not
Try starting Windows in Safe Mode. During boot, before windows starts loading, just keep tapping F8, until a menu appears in which you can select Safe Mode. In Safe Mode, set the resolution to a safe, low value in the control panel. Then reboot normally, and everything should work fine.
Jun 07, 2009 | Acer AL1916W 19" LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
