Question about Samsung SyncMaster 15 GLe (White) 15 in.CRT Conventional Monitor
Control Lock. I have got a monitor problem. When I try to adjust the brightness and colour it said Control locked. Also it always pops up and Iam unable to proceed working. Please help me out in resolving the problem.
    Problem Solver:
  • 19 Answers
If it is samsung TFT monitor problem solution is to press and hold menu buton for more than 10sec.
Good luck.
Posted on Jan 17, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 17, 2016 | Princeton Digital VL173 Monitor
Blue lock pops up. can not use menu buttons. screen is too bright.
The lock that pops up is called OSD Lock, with this there are no adjustment can be made by a user and only menu button will work. For you to disable it, just press the menu button for about 15 - 20 secs.
To know more about the controls of your monitor please click on the link.
I hope this will be able to help you resolve the problem.
Thank you for choosing Fixya
Mar 06, 2011 | Dell E152FP 15" Flat Panel LCD Monitor
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
OSD Lockout and Volume pop up
my monitor always fading into sleep mode or some thing,on & off etc..
Jun 23, 2010 | HP w1907 LCD Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Want to unlock my monitor
This is the function that locks the OSD in order to keep the current states of
settings or prevent others from adjusting the current settings.
1. Lock : Hold down the menu button for more than five seconds to activate
the OSD adjustment lock function.
2. Unlock : Hold down the menu button for more than five seconds to
deactivate the OSD adjustment lock function.
Though the OSD adjustment lock function is activated, you can still
adjust the brightness and contrast, and adjust MagicBright ( )
using the Direct button.
Found at: http://www.retrevo.com/support/Samsung-713BM-PLUS-Monitors-manual/id/2994ag905/t/2/
Hope this helps and please remeber to give me a rating, thanks!
OpenSource13
Apr 06, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Monitor is control locked
you did not given details of model, company complet discreption of problem ok no problem you press the four keys on the monitor for five seconds simultaneusly or till it will show the massage "keys unlocked" then release
Nov 23, 2008 | Compaq P 70 Monitor
Control lock
Temporarily you can -- hold down, while monitor is on and the menu button for 10 seconds (source Samsung faq). This hould unlock the buttons.
This problem is due to abad 7805 regulator ic ora memmory ic
To completely stop this you will have to replace the 5 v regulator
Jun 09, 2008 | SAMTRON 55V 15" CRT Monitor
I have the SAMTRON 56 V 14" COLOUR MONITOR .
change the eprom (A41dDC) after connect pc then switch on monitor
sushil91077rajbanshi@rediffmail.com
Sep 04, 2007 | SAMTRON 78DF 17" CRT Monitor
Samsung SyncMaster 15 GLe (White) 15 in.CRT Conventional Monitor Logo
99 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
