Question about HP DesignJet 1050c InkJet Printer
Hp designjet 1050 problem
Dear all,
the problem is printer switch off, check printerhead type 2.
thanks,
boby
  • davad100 Feb 26, 2009
    Hi all, bought new printheads, inks and head cleaners etc and printed off one drawing yesterday. Brief of what happened:
    Yesterday:
    1. changed all inks/print heads/cleaners
    2. done a print off and it started ok until it showed up black was faulty, we continued and the black images turned to cyan partly, some didnt print at all.
    3. cyan showed replace
    4. balck showed failure
    5. the print was readable but lost a lot of text/images
    Today:
    1. turned on and done self clean
    2. said many times that paper alignment is wrong and remove paper, which we done only for the message "turn off power, check printhead path type (2)" to appear?
    3. turned off and checked printheads and removed/reinstalled etc., turned on power and same again...?
    4. it did go as far as aligning paper itself with paper feed, but 2 above came up again...?
    Not sure what the problem is or why is repeating as all parts were new and HP boxed etc.
    If anybody can help much appreciated.
    Problem Solver:
  • 8 Answers
Oiled the slider rods and ensure there was no debris or damage in the printhead path.
You may also want to check the quality of the encoder strip *CAREFUL! IT IS VERY SHARP* and the belt that moves the carriage.
Posted on Dec 17, 2008
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
Make sure you use nye watch clock oil to lubricate the slider rods, and always clean the slider rods with a degreaser before oiling to remove the old oil.
Posted on Sep 03, 2012
  • 24 Answers
The encoder strip can be cleaned CAREFULLY with a lint-free cloth wetted with clean, luke warm water. Also you should clean the contact matrixes of both the carriage (where the printheads are connected) and the back of the printheads itself. Use either clean water or isopropanol. If this doesn't do the trick, a maintenance kit may be the solution - as long as it still can be supplied.
//Al
Posted on Mar 08, 2009
Designjet 1050 processes but won't print
Does it run out of memory? Could you test printing a very small file? Are you sending an Adobe file to a non post script printer? How large is the file? How do you know it processes?
Jul 09, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp 1050 non-genuine cartridge
What solution are you seeking? They are not recognized by the printer and there is nothing you can do about it. You can try to get a refund (reimbursement) from the seller on the account of false compatibility claim.
Dec 10, 2013 | HP DesignJet 1050c InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
I can't find drivers for HP Designjet 1050c printer running with Windows 7 OS
And you won't.. Because there are none as this unit is considered too OLD. Try this "work around". Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all
Feb 03, 2010 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
443 people viewed this question
Ben Johnson
