Question about Singer 7426 Mechanical Sewing Machine
Singer 7426 will not start when peddle pushed - only beeps
We have checked and rechecked the setup and all threading, etc. yet the machine will not run. Something must be telling it not to start. When the peddle is pushed, we get a series of beeps. Nothing in the manual. We may have to just go buy another machine.
  • mccowandjb Apr 29, 2009
    my singer 7426 just stopped working and beeps one long beep when I step on the pedal. I have re-threaded, un plugged and re-plugged and it still beeps when pedal is depressed. Help!! I am mid project. I was using a free motion presser foot to stipple stitch on a quilt.
    Scholar:
  • 110 Answers
No, dont go and buy another machine. This is a great value for money machine.
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. Pull it down and push it up to the top again. This should sove your problem right away.The beeping sound is a warning message. If the problem persist, do the following procedure:
Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 14, 2008
How do I get my machine to start sewing and stop beeping?
try rethreading the machine--use EVERY thread guide
make sure the needle is inserted up into the needle holder and turned the right direction
make sure the bobbin is inserted correctly into the bobbin case and turned the right direction
clean under the needle plate and in the bobbin area for loose thread or lint
make sure thread has not come off the thread take up lever
also the jam could have caused the machine to jump time and needs a timing or a adjustment
Jun 06, 2015 | Singer 7436 - INGENUITY
How do i change the light bulb on singer model 7426 ?
You have to unscrew the cover of your sewing machine on the left top and once it is unscrewed you take the cover off and insert a new bulb and then replace the cover.
Jul 08, 2014 | Singer 7426 Mechanical Sewing Machine
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
My machine beeps and will not sew when the foot peddle is pushed. i checked the BH lever inside the light cover and the small black switch appears to be in the up position. any other ideas?
make sure the foot pedal cord is pushed in correctly
rethread the machine top & bobbin
clean under the needle plate where the feed dogs are for lint
also clean the bobbin are for lint or loose threads
change needles
but also the foot pedal could have gone out
Nov 19, 2010 | Singer 7422
As I am sewing, it suddenl stalls, starts beeping and the number 88 appears on the display and it doesnt move.
I have looked through your manual online and I cannot see anywhere an error code list. I would call Singer at 1-800-4singer for an answer. That is crazy, you can't fix a problem if you do not know what is wrong.
Nov 19, 2010 | Singer 7426 Mechanical Sewing Machine
I push the peddle down and all I get is beeping what is wrong with my 7442 singer
I would call Singer at 1-800-4singer and find out. I looked up your manual at www.singerco.com for free and don't see any mention of a beeping sound except on page 28. Your machine is a computerized one, not mechanical.
Oct 21, 2010 | Singer 7442 Mechanical Sewing Machine
Singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 25, 2009 | Singer 7426 Mechanical Sewing Machine
The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Oct 27, 2006 | Singer CE-100 Futura Computerized Sewing...
Singer 7426 Mechanical Sewing Machine Logo
372 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
