Question about Food Processors
Can't remove blade from food processor
Can't remove blade from Kitchenaide food processor, So, the processor seems jammed and won't spin.
  • 2 more comments
  • Anonymous Dec 07, 2008
    kitchenaid kfp 600, blade wont come loose from top
  • jmpurcell Dec 26, 2008
    I cannot remove the blade, and cannot remove the bowl from my kitchenaid food processor.
  • Anonymous Apr 19, 2009
    The blades are bound up and won't spin.
  • garrymail24 Apr 19, 2009
    Cuisinart fpb-5pc blades are bound up and won't spin. Using WD-40 loosened the blades a little, but still can't be spun by hand.
snakehead
  • 1074 Answers
SOURCE: Food processor blade stuck on motor shaft
my friend if you had not removed that blade for a while it will certainly stuck due to the moisture that forms on the shaft of the blade holder causing it to have corosion you will have to carry that item to be removed by a qualified tech by you doing it your self could cause damage,which could cost you more.good luck
Posted on Jun 19, 2007
SOURCE: stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Posted on Apr 05, 2008
SOURCE: Black & Decker 'Short-Cut' Food processor
Add me to the list of lookers...my "stalk" finally split today.
Posted on Jun 22, 2008
SOURCE: chopping blade # 70207
customer service number 1-877-207-0923 for hamilton beach
Posted on Nov 16, 2008
  • 10865 Answers
SOURCE: where can I buy repair parts for food processor
Call 1-800-851-8900 and order what you need directly from Hamilton Beach.
Please mark this as a fixya! thanks
Posted on Mar 18, 2009
Jun 16, 2007 | Cuisinart DLC-5 Food Processor
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
My food processor blade keeps popping up (loose) when I put food into it.
You will probably need to replace the sleeve on the motor shaft and the blade. If overloaded the shaft can spin inside the blade which wrecks the connection between them. Replacing both together is the correct solution.
May 16, 2014 | KitchenAid Chefs Chopper KFC3100 3 Cups...
Cuisinart smartpower duet BFP703 food processor repair manual
Oh some of these answers... the most common issue with blender is that the removable blade unit starts to jam. So :
1. unscrew it, clean it and make sure it turns easy
2. open the unit and replace the fuse that blew up because turning the blade became too hard.
Voila
Nov 25, 2012 | Cuisinart BFP-703 SmartPower Duet Food...
I have a Black & Decker FP1550T food processor. The chopping blade is stripped and will not spin. Where can I replace it?
I ordered a new blade at PartStore.com. I looked up the part number on the user manual. The part number for my FP1550T food processor is MP12-2-500.
Aug 18, 2010 | Black & Decker FP1550T Textured Series ...
Jammed cutting blade in cuisinart tube
Try immersing the tube in super hot water. The plastic might expand just enough to let you slip out the blade. Since the tube is dishwasher safe, there should be no harm. A little soap in the water might help it slip out.
Jan 29, 2009 | Cuisinart DLC-5 Food Processor
How do i remove the blade of of the bowl?
Remove bowl lid first
Then twist bowl to left (as you face front of machine)
Lift bowl up - blades will come with it
Feb 11, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
Food Processors Logo
928 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
