Question about Dryers
Dryer capacity Was hoping you'd be able to tell me if my current dryer would dry a full load from a new LG 3.5 cu. ft. washer. I'm trying to avoid spending money i don't really have. I'm considering buying the pair at $1300 vs. just $630. GE Heavy Duty 5-cycle Dryer w/auto dry control, model: DDE7500GALWH Thanks, Kerin hike2alpine@yahoo.com
  • hike2alpine Nov 14, 2008
    Thank you so much! Same for the LG 3.6? I wrote 3.5 by mistake. So glad you responded so quickly!
    Thanks again,
    Kerin
  • 5,911 Answers
Yes, a full size dryer as yours is easily capable of drying a full sized load from the washer you mentioned. The wash tubs in the new model washers and dryers still maintain a standard size. For example, the front loader dryer that I purchased to match my front loader washer is completely identical to earlier standard models without all the fancy packaging. I could have saved some money and purchased only the washer, but...the wife needed a matching pair.
Now, you will still have to properly sort items to ensure they dry efficiently. A copy of your dryer owner's manual will describe this to you. I'm not here to give you lessons in how to dry your clothes, but if you do not own a copy of your manual and would like to refer to it, you can obtain a copy at geappliances.com. Just look under the "Service and Support" section for "Use and Care Manuals". Just type in your model number and your owner's manual is availble in a downloadable .pdf format.
The point I'm attempting to make here is that although you can place a full load from your washer in the dryer, if you do not properly separate certain items, they will not dry properly. I did not want you to think this was a cause of the appliance.
In addition, make sure the dryer vent ducting is properly cleaned and not clogged anywhere. This can also contribute to longer dry times.
I know you were only asking a simple question. I just wanted to be thorough in case additional question may arise. I hope this information is helpful to you.
Posted on Nov 14, 2008
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
LG gas dryer not coming on
I can tell you on the LG dryers there is indeed a "reset" for the heating/burner funnel (as you obviously know) on the right hand side of the funnel, however they also incorporate a no reset "hi-limit thermostat" on the left side of the funnel. Once it is tripped it must be replaced.This is only present on the gas dryers.
Oct 16, 2012 | LG DLEX8377WM Front-Load Electric Dryer...
My extra large capacity Whirlpool dryer does not dry in one cycle. Even if I only put a small load it takes at least 3 cycles to dry
There maybe an air flow issue. With the dryer on check the air flow from the exterior location of your home. There should be a good flow of warm/hot air coming out. If not the inside of the dryer may be full of lint.
Feb 21, 2011 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool 6.5 cu ft 5 cycle is not timing and drying clothes qui
First I would check to make sure your vent is not clogged or kinked. As far as the timer, the only fix would be to replace it. Unless of course you have the feature that detects the dryness and that would put you back at the venting problem. Good luck.
Apr 17, 2009 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
221 people viewed this question
Top Dryers Experts
