Question about LG 42PC1DA 42 in. Plasma HDTV
LG Plasma 42PC1DA screen blank, but sound is ok
What can I do to fix it?
  • mtst73 Jan 20, 2009
    same prob as leeham33..heard it is a common prob with this " LG plasma"...i have 2 of them,they lost Video abt one month apart! just after the turned 2 yrs old! go figure!
    Champion:
  • 225 Answers
Plasma TVs run on decent voltage. It is likely the power supply has encountered some damage. This could be a loose solder joint near a transformer, or a shorted out component. It is a lot of detective work. I would try to find a new power board online somewhere. There are people that pick up broken tvs for a living out there if you would rather sell it. Power board is their favorite type of damage and they offer extra money for them that way.
Posted on Nov 14, 2008
I have a Plasma TV LG model # 42PC1DA. We have perfect sound, but no picture. Tried the contrast, tried unplugging for 30 min. What could be the problem and how much might it cost to fix it?
Did you tried diferent sources from where you get the image? For example you could try to connect a video camera, laptop, dvd or any other thing you could hook it up in your TV and check if there is still no picture.
If the screen is burned it costs the same or a bit less than a new one
Good luck
May 06, 2011 | LG 42PC1DA 42 in. Plasma HDTV
The screen on my lg 42pc1da tv is cracked is it cost efective to repair or replace the tv
That's a tough one to answer with constantly changing prices, and different prices in different areas, but in most cases, a plasma screen is more expensive to replace than the entire unit (especially if you move to LCD or another technology).
You'll have to call around your area and see what places quote you for a new TV and what shops will charge to get you a new screen.
Mar 19, 2011 | LG 42PC1DA 42 in. Plasma HDTV
My 42' LG plasma tv model number 42PC1DA-DU monitor is not show but the sound is working. What should I do?
In this case, the defect is in Y-SUS PCB, change it and adjust the voltage that are specified
on sticker attached to plasma module
Feb 25, 2011 | LG 42PC1DA 42 in. Plasma HDTV
I have an LG 42PC1DA and there is no screen but there is sound. Sounds like the capacitor failed from reading solution posts. I was wondering what i should expect to pay to have it fixed by someone else?
Shop rate will be $200 and up plus parts.
Yes, it can be caps failures in power supply, Z-SUSTAIN, Y-SUSTAIN boards, you also need to check the fuses on all those 3 boards, they are common failure boards.
See the pictures of the boards here:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LG+42PC1DA&stock=all
Please leave rating if it helps.
Jan 29, 2011 | LG 42PC1DA 42 in. Plasma HDTV
LG 42'' Plasma 42PC1DV loud pop,buzzing, no picture cracked screen
pdp panel cracks need replaced
Manufacturer LGE 42PC1DA Part Number EAJ42047868 Description 42 INCH_XGA PDP MODU
Manufacturer LGE 42PC1RV Part Number EAJ42007501 Description PDP,MODULE-VGA
Oct 04, 2009 | Televison & Video
Sound ok. very dim lo color screen
You can check out the brightness and contrast adjustment as your monitor needs further adjusting these settings.
Sep 09, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Plasma tv
Hello
Check the contrast settings
If you are a Technician than just check the video supply from 150 to 200 volts at all three RGB Cathodes in most of cases there would be dry soldering in others it could be due to failure of supply resistance check base biasing voltages if u can provide more information then I could pin point the fault
Good Luck
Nov 16, 2007 | LG 42PC1DA 42 in. Plasma HDTV
Half of the screen only is functioning
ok you have defective vertical amplifier and convergence correction circuit!
Oct 21, 2007 | LG 42PC1DA 42 in. Plasma HDTV
LG 42PC1DA 42 in. Plasma HDTV Logo
492 people viewed this question
Computer Repairing
Computer Repairing
