Question about Microsoft Xbox 360 Console
Disc Drive Problem with disc being read.
Basically, whenever I start up my xbox 360console, it always says "open tray" on the dashboard, so I open it. When I close it, it says "reading", then I heard like a grinding sound, as if it's starting up, then I see "open tray" on the dashboard, again. If someone could help me, I'd appreciate it. Could this problem be dust covering up the laser sensor, which reads the disc?
    Genius:
  • 1,175 Answers
How old is the unit?
Do you keep it at floor level alot? Because this thing ( like all the game consoles) is a dust MAGNET.
Get a can of compressed CO2 ( Dust off)
Open the drawer and shoot into the draw over and under. Reboot .
Cant guarantee anything though
Posted on Nov 14, 2008
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
Won't read the disc.
You can check the Open Tray error troubleshooting tip i have put on FixYa, check the link here
Happy Gaming, please do take time to rate my solution
Regards
KreativeGeek
http://gamingbox.wordpress.com
Jun 08, 2010 | Microsoft Xbox 360 Console
Open tray error and thensome.
Unreadable disc errors or open tray errors are commonly fixed by pot calibration or laser assembly replacement. Pot calibration is the cheaper of the two, and if it fails and burns out the laser, well, replacing the laser would be the next step anyway.
You shouldn't calibrate the pot without an ohms reader simply because you can burn out the laser, but you CAN wing it. I'd advise doing some searching on DVD Drive pot calibration for the Xbox 360, simply because I don't know which drive you have so I can't help identify anything for you.
I will say you have to disassemble it down until you see the motherboard, take out the DVD drive, open it up, and then calibrate the pot with a very small screwdriver. The location of the pot depends on your drive. If this fails, then buy a new laser assembly and replace it in the drive.
p.s. pot calibration is fancy terminology. There are basically 2 "screws" inside the drive, 1 pot is the DVD/games, and the other is CD. You'll want to very slightly tweak the DVD/games pot until it works, testing with each tweak. You barely need to adjust this "screw" for a significant change to happen. Also, always test with a DVD and then a game. It will read a DVD before a game.
Apr 09, 2010 | Microsoft Xbox 360 Console
Will not read disc
Sounds like a DVD drive problem. I have had a lot of success with errors like this by refurbishing the drive. If your not sure how to open or clean an xbox, then maybe let an expert do it for you. EllisonsMP3repair.com is great with repairs like this (cheaper too).
Jan 04, 2010 | Microsoft Xbox 360 Console
My xbox won't start discs and when it does it's not for very long
The disc reading problem is caused by the heat taken on the back of the drive, it is not normally a faulty drive. All you need to do is know how to stop the heat build up and you will be fine!
To do this you can send it in or fix it yourself using a good guide
Jan 02, 2010 | Microsoft Xbox 360 Console
Whenever I want to play my Xbox I turn my tv on then my Xbox. Then I put in my disk and I'm still on the dashboard, so I'm on the slide that says "My Xbox". So I put in the disc it said reading then it...
You are probably right. If it says, OPEN TRAY", it means the xbox did not read the disc. You can try using a cd player cleaning disc. If that doesn't work, then the dvd drive will probably need replaced.
Dec 22, 2009 | Microsoft Xbox 360 Console
Disc tray won't close
Whenever you need help with your Xbox or Xbox 360 accessories, allways check out Xbox Customer Support
The answer to your question is quite long, so here's a link.
Xbox 360 disc tray help
Hope this helps
May 20, 2009 | Microsoft Xbox 360 Console
Wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
May 12, 2009 | Microsoft Xbox 360 Elite Console
Disc Read Problems on 360
you may have a bad disk drive call 1-800-4my-xbox
Feb 22, 2009 | Microsoft Xbox 360 Console
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
198 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
