Question about Toshiba CZ36T31 36" TV
Toshiba CZ36T31 will not respond to remote control
My Toshiba CZ36T31 will not respond to remote control at all. It does not seem to be the remote controller, since the tv controller also operates a Toshiba VCR and that works fine on the vcr. The vcr controller also works and controls the tv, but is not doing so now. Hence, it looks like the infrared receiver on the tv is defective unless there is an "on/off" for the remote. Is there such a switch and where is it located? Thanks, KC
  • 2 more comments
  • Kent Caldwell Nov 18, 2006
    Well, I solved my problem. I was able to manually access the menu and initiated the "reset" function and it now works fine.
    Thanks,
    KC
  • Peter Teeson May 11, 2008
    Exactly same problem. Tried the reset trick last fall and it worked then. However now response from remote is spasmodic. Would like to know how to get factory service manual so as to find out if IR is a separate board which can be replaced or if we just have to live with manual controls.
    Exactly same problem. Doing reset rarely works now although was good last Fall.
    I would like to know where to get the factory service manual to see if the IR is on a swappable board or on the main board.
    Speaking to local repair dealer they just want to send a serviceman and minimum charge of $75.
    If it's a simple board swap I can do that!
    TIA for suggestions
    resepct....
    Peter
  • jaydylan Jul 17, 2008
    how do i find the reset?
Finally hod this fixed. Toshiba gave me the names of 3 authorized repair shops. They all wanted between $150 - $200 to come to the house and do the repair. They cited replacing "the processor" etc.
But my brother-in-law had talked with a chinese man in a mall and we spoke to him. He said probably no need to replace anything. If he came to the house and fixed it with no parts it would be $80. If he couldn't fix it it would be $15 to cover the cost of the gas.
So he came the same day, in the evening. Turns out it was a cold solder problem with the diode that feeds power to the IR sensor. Took him 1/2 hour from the time he came in the front door, fixed it, and left. Just goes to show you what old time service and understanding can do. Most repair techs today only know how to replace boards not to really trouble shoot for the obvious.
respect....
Peter
Posted on Aug 02, 2008
    Genius:
  • 1,074 Answers
Happy for you that you has solve your problem congratulation.greetings from belze blessed my friend.
Posted on Mar 23, 2007
Toshiba Regza defective TV remote control replaced with manufacturers unit but TV still not responding
Sounds like its control panel [TV] micro-switch has the fault. If any one among it do have an internal short circuit; this kind of fault can occur. Contact any service technician. It will be the best. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 22, 2015 | Toshiba Televison & Video
Can not find codes for toshiba remote for my sony dvd home theater changer nor any specifics on hooking it up properly and it has s video but no hdmi hook ups help By the way i already pd 1459.00 dollars...
To find the code for the Toshiba remote to the Sony DVD changer.
If you do not know the device code for a particular device, you can view each available code for that device mode and sample the functions to find the code that operates the target device. 1 Press a mode select button on the remote. 2 While holding down INFO button , press 8, 5, 0, 0. The remote control enters program mode. 3 Point the remote at the target device and press Power button, 1, VOL UP, CH UP or PLAY. Some keys are ignored if they are not applicable to a specific device mode. 4 If the device responds to the remote control: Press INFO button to store the device code. The mode select button blinks twice. The remote exits program mode. 5 If the device does not respond to the remote control: Press UP. Press POWER. Repeat this step until the device responds to the remote. Press INFO . Note: When a search cycle is completed, the mode select button blinks 3 times. The remote displays each available code again. If no key is pressed within 10 seconds, the remote exits program mode and returns to the previous code.
The previous section was from the manual p.86: http://www.iusermanual.com/tv/toshiba-46vx700u-tv-manual.htm
Hooking the DVD changer to the TV: The TV has composite video inputs and can accept s-video by a adapter cable as in: http://www.amazon.com/S-Video-3-RCA-Composite-Cable-Laptop/dp/B002ZKTCUM/ref=pd_cp_e_1
May 05, 2011 | Toshiba 46VX700U LCD TV
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba CZ36T31 will not accept remote codes for dish network
Hello!!! It has been awhile, so I do hope that you were able to get your remote working with the tv. If you have not, or are having any other troubles, here is something that will help you. Follow the link below, and you will find instructions for a power scan. the power scan scans the tv for all codes on the tv for the code that works with the remote. It sounds like a tedious process, but it is actually very quick, simple, and efficient.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
May 22, 2010 | Toshiba CZ36T31 36" TV
Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
I have a 2004 Toshiba color TV 27".
simply look up the codes or contact your cable company for the toshiba tv codes to input into the cable remote. you may also be able to operate the cable box via the TV remote if the correct codes from the tv owners manual are entered.
Nov 25, 2008 | Toshiba 27A33 27" TV
Remote does not work
Just found this bit of info on a CZ36T31 elsewhere and am posting it in case it helps...
"...and an intermittent problem responding to the
remote. I had a service person check it out and was going to have it
repaired because it still looks and sounds very good. The part was
available at a cost of about $85-90 plus about $40 for the service.
However, the service person didn't want to come back again for
another service call because I was too far and it was not profitable
for him, so the part was never replaced.
The remote control is OK. It is the receiving module in the TV that
has a low voltage problem. If anyone is electronically handy it
probably is an easy fix to install a new module or it can be use
without the remote with the buttons on the TV."
May 11, 2008 | Toshiba CZ36T31 36" TV
Toshiba 15DLV16 lcd/CD combo
mostlikely code is 11256 if ok select switch on the remote is red
Dec 26, 2007 | Toshiba CT-90157 Remote Control
Toshiba TV CZ36T31 & Toshiba SD1600U
go to http://www.devicemanuals.com/company/Toshiba-page5.html here you will get user manual you will get all information along with figure. good luck.
Oct 07, 2007 | Toshiba CZ36T31 36" TV
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Nov 21, 2006 | Toshiba 32AF43 32" TV
Toshiba CZ36T31 36" TV Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
