My Canon i860 is not printing magenta. I run all the maintenace functions -- nozzle check pattern, print head alignment, cleaning, and deep cleaning -- twice. Problem persists. The magenta ink tank is near full and firmly installed. It's also not Canon equipment. What do you suggest?
    Master:
  • 505 Answers
If everything is clean and working fine then you need to first replace the ink tank and then check.
Also check if its happenning with eery application or some specific applicaion like MS WORD or MS POWERPOINT.
Thanks
Posted on Nov 14, 2008
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Canon Pixma MP620 problem. It prints with a thick white lines going horizontally, so that the texts are faded out and not legible.
You probably need to run maintenance on the printer.
On the LCD do the following: (1)Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Nozzle check pattern, and press the OK button. (4) Select Yes, and press the OK button. The nozzle check pattern will be printed and two pattern confirmation screens appear on the LCD.
This will tell you if the nozzles are out of alignment or not.Regardless you should not run the deep cleaning on the print heads. From the LCD do the following and make sure you have several sheets of paper in the printer;
(1) Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Deep cleaning, and press the OK button. (4) Select Yes, and press the OK button. The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 1 minute 30 seconds. (5) Select Yes, and press the OK button. The nozzle check pattern will be printed. (6) Check the nozzle check pattern. See Examining the Nozzle Check Pattern. - If a particular color is not printed properly, replace the ink tank of that color. See Replacing an Ink Tank. - If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours. - If the problem is still not resolved, the Print Head may be damaged. Contact your Canon service representative.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
I HAVE A CANON MP 760 PRINTER THE MAGENTA COLOUR LINE IS TWO TONED WITH DARK AND LIGHT PINK . SO WHEN PRINTING PICTURES THERE IS DISTINCT LINES CAN SOMEBODY HELP HAVE TRIED THE CLEANSING REPLACED THE...
You need to conduct the following steps:
The nozzle check pattern shows if each print head nozzle is operating properly.
You can also print the nozzle check pattern from your computer.
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press <Feed Switch> button to select the paper source.
  3. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  4. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  5. Use left or right arrow to select [Maintenance] and press <OK>.
  6. Use up or down arrow to select [Nozzle Check] and press <OK>.
  7. When prompted to print a nozzle check pattern, use the up arrow to select [Yes] and then press <OK>.
    The machine prints a nozzle check pattern
Print Head Cleaning / Head Refreshing
If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head.
MEMO:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  2. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  3. Use left or right arrow to select [Maintenance] and press <OK>.
  4. Use up or down arrow to select [Print Head Cleaning] or [Head Deep Cleaning] as necessary and then press <OK>.
When prompted to clean the print head, use the up arrow to select [Yes and then press <OK>.
IMPORTANT:
If normal print head cleaning does not improve print quality, perform deep print head cleaning.
Print Head Alignment in Windows
If colors mix or streaks appear in the nozzle check pattern, perform the print head alignment.
The print head alignment can be performed either automatically or manually.
If the automatic print head alignment does not resolve the problem, perform the print head alignment manually.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
206 people viewed this question
jasbo
jasbo
