Question about Procom Heating & Cooling
Too much sweat is on my windows in cold weather.
When I use my vent free Pro-com gas heater in colder weather a lot of sweat forms on my windows. Is there a way to vent the heater and solve this problem?
    Problem Solver:
  • 17 Answers
Vent free is the problem, 1 of the combustion byproducts is a large amount of water vapor. Crack a door to the room a little and maybe even a windw slightly (as it most likely states in the owners manual) and see if the problem goes away.
high himidity + warm air+ cold window glass = condensation
fresh air circulation = less condensation and also less CO and other bad things in the air you are breathing...just because its vent free does not mean its not dangerous in a tightly closed room. The vent frere designation assumes a certain number of air changes per hour and you are not getting them.
Posted on Nov 14, 2008
How much steam should be comming out of vent pipe on a rayvac propane heater?
You'll see steam if it vents outside,especially in cold weather. Burning propane creates water as a by-product. That's why well-insulated houses get condensation on the insides of their windows when unvented heaters are in use. don-ohio (:^)
Jan 27, 2017 | Heating & Cooling
I have a vermont castings radiance 2600 fireplace, the pilot light is lit but the on switch isn't turning the fireplace on
desa is out gone but maybe pro com have a controller with the same controls as the desa check #on the control and see cross ref in Google search they can be 80.00 and up but can b found
Dec 10, 2013 | Rinnai Desa Vent-Free Infrared Gas Heater:...
2000 Mitsubishi diamante runs great till weather turned cold now having problems with idle dropping at lights and dying. New plugs and wires new battery cables and wires and good battery. Need opinion
  • This will happen to a lot of people as the weather begins to cool. I suggest making sure you get gas from a reputable service station for one. Just as important make sure to put a bottle of HEAT in your tank with every fill up(half a bottle for half a tank fill up on fuel).
  • What happens is there is already a certain amount of water no matter where you get fuel from as the storage tanks have a lot of water in them. That alone with the colder weather makes for rough starts and at times poor running conditions in the colder months because water freezes and makes the gas hard to pass through to the injectors and greatly effecting the engine firing properly. Heat will dry this water up and make your fuel flow much easier and burn a little better too.
  • Try this and you will notice a difference. Just about anyone will during the colder months.
  • Hope this helps.
Nov 03, 2011 | 2000 Mitsubishi Diamante
Have a customer who has model # 1403622, when not in use the customer gets cold air coming inside from outside. suggestions?
This is a recurring problem with all Direct Vent Gas Appliances. Whether it be a Direct Vent Gas Fireplace or a Direct Vent Heater like you customer has. Not to mention, that they are very inefficient.
Unfortunately, there are only 2 solutions: Cover the direct vent outside when not in use. Of course, that means remembering to uncover it before each use. The other solution and the most efficient is replacing it with a properly sized Vent-Free Gas Heater or perhaps a Vent-free Gas Fireplace depending on what type and size room the present heater is in.
The following website as a lot of information o these types of products and how to properly size them.
www.americanhearthandhome.com
If the link doesn't work when you click on it, copy and paste it into your web browser.
Jan 24, 2011 | Williams 1403622 Gas Compact Heater
Bosch AquaStar tankless natural gas water heater pilot goes out periodically--after a few hours or a few days, whether weather hot or cold, whether windy or not. This condition has been the same from day...
I had a similar problem with mine and it turned out to be a plugged air vent sceen. This is the small dome like sceen on the gas valve. I vaccumed out the unit and have not had the pilot go out in over a year.
Nov 27, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Rinnai 506 silent servant vent free propane heater, can I switch it for use with Natural Gas?
yes you can, but is complicated, involves changing injector, burner, and reprogramming the PCB for the new gas type. Get a pro to do it for you
Nov 30, 2009 | Rinnai Vent Free Gas Heater/
Patio Heater SRPH02 will not light in cold weather
you may need someone to come in and adjust your pressure regulator that is inline to heater this is what controls the output of propane and should only be adjusted by a pro
Apr 15, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
2003 Saturn, DOHC V6, burning smell in interior after car warms.
if the smell only comes on when the heater is on try pulling the blower motor mice like to build nests in the blower motor housing.
Mar 21, 2009 | 2003 Saturn VUE
Frigidaire frostlfree upright freezer ice forming top interior door
Not sealing. warm air hitting cold air causing frost. also, door frame heater may not be working. most frames are "warm" to the touch. normally called an "anti sweat" heater.
Jul 15, 2008 | Freezers
Heating & Cooling Logo
124 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
