Question about Kitchen Ranges
Oven temperature indicator light does not turn off
The oven temperature indicator light does not turn off when the oven has reached the desired temperature.
The oven works fine and by using a thermostat I can validate that when the desired temperature is reached the elements turn off.
Moffat stove model MRMF3150VM-2
5 Suggested Answers
SOURCE: viking oven won't heat
Igniters need to be replaced
Posted on Aug 26, 2008
daddy1264
  • 76 Answers
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Posted on Jan 01, 2009
SOURCE: I have a kitchenaid gas stove model
I had what seems to be a similar problem with my range, which is a KitchenAid KGRT607HGL6. I'd turn it on, and sometimes it would light, sometimes not. If it didn't light, I'd start smelling gas and I'd have to ventilate the kitchen. If it did light, it took forever to heat up.
That said, I have just finished doing the things I'll describe below, and the oven appears to be operating correctly now. I'm not going to go as far as to say this will work for you, and I'm not even sure which step was the key (maybe it was a combination of everything), but I'll tell you what I did.
PLEASE be careful. Gas isn't something to be messed with. If you have any doubt, you're far better off calling a repairman than blowing the side of your house off, or worse, hurting yourself.
It might help to download this parts list, and refer to page 9, so you know which parts I'm talking about:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208187617.pdf
Here's what I did:
1. Removed the racks from the oven.
2. Removed the pan from the bottom of the oven (it just lifts out).
3. Removed the flame shield by taking out the 4 screws holding it down.
4. Turned on the oven, and saw that the element glowed, but that the gas took forever to ignite. When it did, the flames were weak, shooting out perhaps 1cm from the burner. NOTE: For whatever reason, if I opened and closed the oven door every 30 seconds or so, the oven would start. If I just left the door closed, no such luck. ANOTHER NOTE: If I started to smell gas while I was standing by the oven, I shut off the oven, opened some windows and tried again later. I'm not a fan of emergency rooms.
5. Shut the power off to the oven.
6. Unscrewed the ignitor from the bracket that holds it in place inside the oven at the back.
7. Wiped off the burner element (there was a little buildup, sort of like gray dust).
8. Unscrewed the bracket holding the burner to the oven, allowing the burner to be moved around (can't be entirely removed, just wiggled).
9. Removed the storage drawer from under the oven.
10. Using a hose attachment, vacuumed all around the area where the valve and regulator send gas up into the burner (about center, back under the oven). Look for a brass nut sticking up into the end of the burner tube. With the burner unscrewed from its bracket, you'll be able to lift the burner up a bit and vacuum around it a little better.
11. Reattached the burner and ignitor to the bracket inside the oven.
12. Turned the power back on to the oven.
Then I turned the oven back on, and the ignitor glowed for 30-60 seconds and then the gas kicked on with much more flow than before, (core flame cones about 1.5 cm long with more even flame out beyond the cores) and the oven heated up immediately. I'll replace the flame shield, oven pan and racks when it cools back down.
My guess is that there was something (lint, cobweb, dust bunny, who knows) partially blocking the gas flow into the burner tube.
One other thing I did after the oven seemed to be working was to adjust the air shutter at the base of the burner tube, right where it meets that brass nut under the oven. I got that from Installation Step number 28 (page 6) on the following PDF:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%209755235.pdf
Like I said, I don't know if my solution will work for you. Try it at your own risk, and DON'T DO ANYTHING BUT SHUT OFF THE OVEN IF YOU SMELL GAS. :)
Posted on Aug 29, 2009
  • 35 Answers
SOURCE: Oven and elements do not function on an old electric range
check for 220 volt to range
Posted on Jan 02, 2010
SOURCE: Hotpoint BU72 Cooker - Oven not getting to temprature
Lower oven has new element but still not reaching correct temperature.
Posted on Jan 07, 2010
Why hasn't the oven reached the set temp when the buzzer sounds indicating desired temp has been reached?
What are you using to measure the temperature of the oven? If you using a typical round oven thermometer, the reason is that your thermometer response is slow. It takes about 20 minutes for those thermometers to reach and display the actual temperature, and your oven is probably reaching it's set temperature in about 10 minutes. You really need an electronic thermometer or at least one of those liquid thermometers which you can sometimes find at Ace Hardware or True Value Hardware stores.
Apr 29, 2015 | Kenmore Kitchen Ranges
Oven doesn't stop heating at desired temperature
It sounds like a welded contact in the relay supplying power to the heating element.
Apr 25, 2014 | Frigidaire Kitchen Ranges
After oven reaches desired temperature, it has late ignition that turns off the pilot AND OVEN WILL NOT STAY ON.
Sounds like the pilot is mounted to far away from the burner. I have seen it happen before where the pilot has detached and the main burner will just keep pumping gas in until it hits the pilot flame and just flash flames and everything goes out.
Or it just could be a bad thermocouple that is going out all the time.
Mar 01, 2013 | Southbend S36D 36" 6 Burner Gas Range,...
Onece the range selector is turned on the light comes on but soon goes out, if you move the selector a little the light comes back on, this stove was made around 1952. Thank You, Dave
Are you talking about the oven temperature control? When turned on to the selected temperature the oven indicator will light and the element will work. When the oven reaches the desired temperature the power will shut off to the element and the indicator light will go out. When the oven cools slightly the indicator light and the element will again turn on. When it does turn off and you turn the knob slightly to increase the temperature the indicator light and element will come on again as you are asking it to heat to a higher temperature. This is normal oven operation.
Mar 10, 2011 | Kitchen Ranges
The oven does not cook the food, it only warms the food.
Two possible problems. If the oven has two or more elements for normal operation then one of these elements may be faulty. The thermostat may also be faulty and only heating to a far lesser temperature than required. The way to tell is turn the oven to a normal cooking temperature.
If the oven indicator light stays on all the time and doesn't cycle off then it may be an element problem, meaning that the oven can't reach the temperature setting desired.
If the oven indicator light goes off after a while and then cycles on and off then the thermostat is working correctly but the temperature may not be hot enough. You may have to purchase a small oven thermometer and check the oven temperature against the thermometer to get a better idea of what the problem is.
Feb 10, 2011 | Viking Ovens
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
176 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
