Question about Hoover Washing Machines
HOOVER 800ORD - it takes forever to fill washing machine. had a serviceman replace the valve in april 2008 but this has not made any difference. currently takes 2hrs 20 mins for 1 load. Help!!!
  • 85 Answers
Romove your water lines and there will be small screens inside that need to be cleaned
Posted on Nov 14, 2008
Hoover 202m 5.5kg washer takes a long time to fill on cold
Check tap turned on fully, kinked fill hose, filter in fill valve where hose screws on to machine.
Sep 30, 2017 | Hoover Washing Machines
My Hoover Galaxy is not filling up,only the Hot water tap works.
sounds like the cold water intake valve has failed and will need replaced
its solinoid coil is prob open circuit
Dec 14, 2014 | Hoover Washing Machines
Hoover Elite 920 top loading washing machine will not fill. I can manually fill the machine and it will run through a cycle until fill is required for rinse cycle and then I have to manually fill again I...
first check the water is switched on to the machine. If it is then you most likely have a faulty water valve. Switch all power off and remove the top panel should be 4 screws or so. If it has 1 valve then replace it.
Mar 09, 2011 | Hoover Washing Machines
Takes forever to fill water bearly comes out
The water line valves will need to be replaced. The are electrically operated valves so remove all power before replacing them. They are located under the hood, top rear of the machine.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
When washer fills with cold water there is very little pressure and it takes forever to fill.
Turn off the cold water valve.
Remove the cold water hose from the washer. Clean out the filter screen on the water valve. Replace the hose and run the washer.
Apr 21, 2009 | Washing Machines
Hoover 500 top load washing machine - water in-flow very, very slow
Check the water valve. Most of the hoses that are hooked to the water valve have a screened filter, turn water off, unhook hoses, check to see if they need to be cleaned. Other wise the water valve is bad and will have to be replaced.
Jan 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
