Question about Check Point Network Adapter
Changing digital combanation on safe
I have a bunker hill digtal safe recieved it as a gift no instructions on how to change cobanation can you help model # is 45891
  • bluntastic_c Nov 20, 2008
    i have a bunker hill digtal safe recieved it as a gift no instructions on how to change cobanation can you help model # is 93575
    Problem Solver:
  • 6 Answers
Manual for bunkerhill safe , how to program and specs:
http://www.harborfreight.com/manuals/93000-93999/93575.pdf
No Known default combination.. Sorry!
Posted on Oct 29, 2009
    New Friend:
  • 3 Answers
There is a button on the inside of the door when you got it open hit the button a put in your new code and hit a or b
Posted on Nov 29, 2008
To reprogram a Brink 5074 safe There is a way to check and see if the batteries are low: On the Keypad, press B
If the Red Led Flashes, change the batteries within 2 months
If no LED lights change the battieries immediately.
To change the batteries, you will need to open the safe door. The battery compartment is on the back of the door. If this does not solve your problem, you may need to reprogram your passcode. To do this,
1> Open the door using your key.
2> Locate the red button on the inside lower edge of the door
3> Press the button; then release it and you will hear a beep.
4 Now enter a new combination of between 3 and 8 numbers that you wish to use as a passcode, and confirm by pressing the letter “B”. Be sure to write them down immediately, so you don’t forget how to open the safe.
5. Your passcode alone will now open the Safe; To open the safe, push the numbers you have selected followed by the letter “a”.
Posted on Dec 30, 2009
The safe is a Bunker Hill Digital Floor Safe with the following number JH0525710Item 45891 SKU P45991 I lost the code several years ago and don't have a key. How do I open the safe?
In the absence of a code and a key you can't. If it were easy to get into a locked safe, there would be no point. They exist to stop exactly what you are trying to do.
It appears to be a Harbour Freight brand, so you will get no help there.
http://www.ehow.com/how_6546958_open-hill-digital-floor-safe.html
This shows it is Harbour Freight and specifically says they don't supply replacement keys.
Owner's Manual & Safety Instructions
pdfstream.manualsonline.com/9/9e66a90a-2061-4a6f-be5c-10125e503262.pdf
Visit our website at: http://www.harborfreight.com ... To ensure security of your safe, Bunker Hill Security ... Only use this Safe on a stable, level, clean and dry.
Get a locksmith to drill the door off and get rid of it.
Feb 02, 2017 | The Computers & Internet
Is bunker hill safe 45891 fire & water proof
Per the manual, the safe is not fireproof. I will also guess that it is not waterproof, based upon the construction of the safe.
Sep 23, 2014 | Computers & Internet
How do i get into my bunker hills digital floor safe 45891 when i have lost the combo and the keys?
Try banging on the top of safe with hand, rubber hammer, regular hammer with board on safe to spread the energy, etc. while turning the knob at the same time. Sounds silly but worked for me. Sellingdj......
Jun 16, 2014 | Check Point Network Adapter
I have a bunker hill safe #93575, the battery is getting low. is there any thing i need to know about changing the batterys
Change batteries ASAP because if your batteries die you will be unable to get into the safe without the key. The batteries are located inside the safe. If you can't open the safe, you can't replace the batteries!!!
There are NO replacement keys available for model #45891. We've tried. I would NOT buy this safe again for these reasons.!!!
Nov 08, 2011 | Check Point Network Adapter
Bunker hill safe model no.45891 bought used, can't open. any ideas?
Safe has Key lock hidden on it? Contact Harbor Freight with serial number, to try and get new key. Once opened follow these instructions at:
Oct 20, 2009 | Check Point Network Adapter
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
I bought a safe from a garage sale and cant poen it
I know Harbor Freight sells some of their products and you can download the users guide from their website it should help you get it working. Good Luck with it!
Aug 06, 2009 | Check Point Network Adapter
Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
May 16, 2009 | Check Point Network Adapter
Bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
Dec 19, 2008 | Check Point Network Adapter
Check Point Network Adapter Logo
3,414 people viewed this question
Top Check Point Computers & Internet Experts
DROPNDEAL
DROPNDEAL
Laxman Bisht
Laxman Bisht
Gil Shultz
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
