Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Burning when the vacuum was started today it didn't sound like it should and then started to smell like the motor was burning. this is less than 1 year old!!!!
  • 833 Answers
A guess: either there is something in the fans, stuck in the tubes or the belt is being held in position by debris causing it to burn.
Posted on Nov 20, 2008
Burning smell and noise from vacuum
The roller head may be turning, but something could be rubbing and causing the belt to slip slightly. I'd remove the belt and beater bar and look for foreign material that is stuck
Jan 07, 2015 | Sebo ET-1 Powerhead White
Hoover vacuum started smoking
Sounds like the roller became stuck and the motor burnt the belt into. I worked on Hovers for years and that is the most common problem.
Apr 02, 2014 | Hoover U5750-900 WindTunnel Bagless...
My dc24 has started making a loud noise which seems to be coming from the ball. I switched its off when it started to smell of a slight burning or warm smell. Vacuum is only 2.5 years old, filters are...
Sounds as if there is something stuck in the vacuum causing the beater bar to stop turning while the belt continues to turn giving off the burning smell.
Oct 27, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
My dyson has stopped working. There was a burning smell and then a strange noise and now it wont even switch on.
The Motor sounds like it has gone bad. Bagless machines like these always have motor problem. If it is under warranty then it will need to be shipped to Buffalo New York. I would trade in in on a Riccar vacuum. You can get 20 years out of those for less money.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hello, I have a problem with my Eureka Powerline bagged upright vacuum. It has a 12 amp motor and is model #4352, Type D. It was probably bought new in 1998. My problem is, while vacuuming today the motor...
it sounds like a rubber sealing in the motor has come loose and is being constantly rubbed against the walls of the motor with would cause the smell and loss of motor speed caused by the fricton of rubber against the rod so if you can get to the motor try to open it and see if you can get it if not take it to a small engine repair service hope this was helpful:)
Nov 16, 2009 | Vacuums
Does not vacuum effectively. It smells like it is burning. I have only had this one year and hardly use it. When I brought it to a local vacuum repair place, he wanted to sell me another one, and, of...
The burning smell may be the motor that's on its way out. Vacuuming with a blocked pipe or sucking up liquids may cause the motor to burn prematurely. The motors arent very expensive, but on the small vacuum cleaners it is sometimes more cost effective to go for a cheap second hand vacuum than to fix it. Depends on if the guy that fixed it is trustworthy, but i can guarantee you the secondhand machine will not have a lifelong guarantee on it. ask for prices on the motor and decide which you can afford.
Oct 28, 2009 | Miele S548 Bagged Canister Vacuum
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Vacuum cleaner makes a burning smell
spark is from brushes not to worry it's normal but you should change the belt
thumbs up
Aug 17, 2009 | Vacuums
Vacuum making high pitched noise and smells like motor is burning
try repair first for quote and if too expensive then replace. 5 years is about the average life span.
Jul 01, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
170 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
