Question about Hifonics TX1505D Car Audio Amplifier
My Hifonics TX1505D
My amp just died and its not even a day old, it was brand new and everything was hooked up right i was just in the middle of a song and it just blanked out i tried absolutely everything and it wasnt being overdriven and it was not at a low impedence i changed fuses and checked every connection my LED wont even come on.
Stop trying to hook it up your self and go to the professionals.
Posted on Nov 18, 2008
If you have a power capacitor hooked in with your amp unhook it and see if the amp works without it .
Posted on Feb 18, 2008
    Problem Solver:
  • 8 Answers
Dude check your remote wire and your ground also make sure you power wire hasn't come undone anywhere i mean really look at this stuff
Posted on Dec 15, 2007
I have a brand new Hifonics amp 1500 watt Brutus the only thing that powers up is the logo the power light and protection light stay off the amp brand new out the box what can be the problem
Some amps will not power up internally if u donot have remote wire. Also if u connect power then remote wire it will not power up until u reconnect in correct order. But if all that is ok. Than u have a bad amp
Mar 11, 2017 | Hifonics Car Audio & Video
Bridging hifonics vii
find the minimum impedance supported by your amp so you dont burn it up.
look here.
http://www.the12volt.com/caraudio/boxcalcs.asp
Oct 14, 2013 | Car Audio & Video
The amp from time to time gives a tone to the speakers even when the rca audio cords are not hooked to the amp the protect light isnt on and all the wires work properly i hooked different amp to the...
You are on the right track. It's not the amp, but it is the rca wires. When you have them plugged into the stereo, you can touch them together and it will make the same sounds you described also, though I don't recommend doing that! Rca wires can be weird sometimes but usually I replace them with new ones. Even a brand new set of cheap ones will do the same thing sometimes. The noise you here is causes by either a small short in the wiring, running the rca's to close to the power wire for the amp (or any other power wire for that matter), and sometimes you can buy a grounding kit for them that is fairly cheap that will help. Most of the time for me, it was just the connections, but replacing them basically took me through all these steps at once. Just remember, you still have a chance that your head unit is the cause by the connections getting old and wore out on the inside. Hope this helps!
Aug 05, 2010 | Hifonics BXI 1606D Car Audio Amplifier
Brutus amp output problem
must be a bad amp..have you tried bridging them maybe youre channels are out it happens even if its brand new...factory deffects
Feb 21, 2010 | Hifonics Brutus BX 1605D Car Audio...
I got all power from my hifonics amp but no output. everything is hooked up correctly was working but all of a sudden stopped
check to make sure your rcas are good, check to make sure all your connections to your subs are good and if they are most the time this meens your pre amp in your amplifier is out.
May 04, 2009 | Hifonics Brutus BX 1605D Car Audio...
I need a bass knob for my crunch amp
i need an bass knob for an planet audio rxd2400
Mar 01, 2009 | Hifonics TX1505D Car Audio Amplifier
2 4ohm dvc subs to a bxi 608 ( 600watt mono)
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
Jan 29, 2009 | Hifonics Brutus BXi 606 Car Audio...
Hifonics Brutus BXi 1208d Amplifier
Possibly you need to return the amp and get a new one cause that could mean an internal problem and its deffective, you could try replacing the fuses or try changing the ground wire, this problem is very unusual
Sep 13, 2008 | Hifonics Car Audio & Video
Remote bass knob help
i don't think you'll have any problems if the hook up will fit. i myself have a lighting audio bass knob hooked up to a jensen amp and haven't had any problems from that
Dec 12, 2007 | Hifonics TX1505D Car Audio Amplifier
Overheating
The Kicker 10 may be running a 1 ohm load and that amp isn't 1 ohm stable.
Sep 08, 2006 | Hifonics Generation XI Thor Car Audio...
Hifonics TX1505D Car Audio Amplifier Logo
134 people viewed this question
Top Hifonics Car Audio & Video Experts
Mike Duncan
Mike Duncan
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
