Question about Panasonic PV-C1332W 13 in. TV/VCR Combo
Remote help with a panasonic tv vcr combo with direct tv.
I have a panasonic tv/vcr combo. I have found the codes for both tv/vcr and they work fine but when I turn everthing on I have to push the line button on the tv/vcr for the direct tv to come on.
  • 54 Answers
SOURCE: need codes for toshiba tv
You will find the codes you need here : http://www.mykameleon.com/support.html#rs
If the exact code is not listed for your model then you must do the code search. This sometimes takes a while because you have to search through every possible code! Goodluck!!
Posted on Aug 17, 2008
SOURCE: i have a panasonic omnivision
I have the same tv/vcr combo and according to my Advent unversal remote chart Panasonic code =
one of : 1003, 1054, 1062, 1109, 1170 or 1248
According to my Phillips universal remote chart = 416, 937
Hope this can help you
Posted on Mar 08, 2009
  • 21 Answers
SOURCE: can't find comcast remote codes for panasonic
Most universal remotes will not work with TV/DVD/VCR combos . Sorry!
Posted on Mar 26, 2009
SOURCE: Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
I was having the same problem a few months ago. I had another vcr on top of the unit. My son told me nothing should be on to and sure unough when I took the weight off it worked just fine. Hope it works for you.
Posted on May 20, 2010
SOURCE: Remote code for Panasonic TV/VCR combo
Use the RCA universal control programing the code 109 in vcr funtion and will work..... i try and work....
Posted on Nov 23, 2010
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
Jan 01, 2016 | Panasonic Televison & Video
What is the TV remote controller code for a Panasonic Model # PV-C1320?
Hello
Universal remote codes for Panasonic TV/VCR combo are:-
0374 0381
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 04, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Need TV codes for using the comcast DTA remote
I just went through this last night with combo, similar model. They tell you to use the power off test to see when you've got it - nothing worked for that. Then I tried the Panasonic codes and used the volume control as a test, which is much more important, and I found the 3rd code worked for that. I figured, close enough for me, and better than nothing.
Sep 09, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
I have a panasonic omnivision vcr/tv combo and i had to buy a universal remote; i have an RCA rcr312w universal remote, but i need the code in order to program the television; what is the code?
Dec 22, 2008 | Panasonic PV-C2061 20 in. TV/VCR Combo
Need codes for panasonic tv/vcr combo jumbo remote
i have found these codes for panasonic tv/vcr combos - 0035 0162 hope that helps .
Dec 20, 2008 | Televison & Video
Panasonic omnivision tv/vcr combo
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Oct 10, 2007 | Panasonic PVQ-M2509 Combo
Panasonic PV-C1332W 13 in. TV/VCR Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
