Question about Peavey PRO-12 (00497070) Main / Stereo Speaker
REVERBERATION I HAVE A HALL OF 250FT LONG AND SEEM TO BE HAVING PROBLEMS GETTING CLARITY OF SOUND. WHAT DO I NEED TO DO? WE HAVE CONSIDERED THE ACOUSTIC OF THE HALL AND I LEARNT THAT I NEED TO ADD MORE OF THE MID-RAGE SPEAKERS. DO YOU THINK BUYING THE PEAVEY PRO-12 MAIN STEREO SPEAKERS WILL BE IDEAL?
    Scholar:
  • 73 Answers
Clearer sound = more watts / more power.
amp watts? speaker load/impedence ohms output from amp? those peavey speakers will sound good if they are powered correctly. plus try to keep the mic away from the speakers, which brings me to my next suggestion..... mic??? this will also affect your clarity.
yostamplifier.com
Posted on Jan 21, 2010
LE error (checked stator and replaced HAll sensor already)
If the control board does not receive the input it will not operate does the door lock? However:
The attachment shows how to diagnose and repair a failed hall sensor, the usual cause of
an LE error code.
DO NOT replace the stator until the hall sensor has been tested. 98% of LE error codes are
caused by failed hall sensors.
[DD motor SVC check process ]
Pre Check
1) Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for
smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the
drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
2) Don't replace the PCB when the hall sensor is replaced.
Check the hall sensor as shown in the new process.
O have a file I can send but can not upload here if you want it, contact me melissamaemartin@yahoo.com please put hall sensor in subject line. Thanks
Mar 28, 2014 | LG WM-2277HW Front Load Washer
LG WM2487HRM washing machine will not do spin cycle. Get a loud humming noise, no error code. Just replaced the hall sensor, but still getting the same results. No change. Any suggestions?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | LG WM-2277HW Front Load Washer
Having problems getting audio from my creative speakers
What sound card do you have? What model is the computer?
Oct 25, 2009 | Creative Labs sb audigy 2 2zplatn 2 zs...
Both of our car radio are having problems. in one
have a car audio installer check the setup of you system seem like you have something connect wrong check you get signal you should get sound if unit is not deffective
Oct 09, 2009 | Sirius Satellite Radio Receiver
I am using Jbl 1200w woofer
actually i want tat d voice effect should b lik a surround system nd for tat i hv 2 increase d volume...by increasing the volume it gives a wonderful effect outside but m nt gettin ane vibrations inside ma car nd moreover i think thr is sm problem with vocals..shud i go 4 sm tweeters so tat sm clarity effect can b increased?..
Apr 09, 2009 | JBL BassPro Car Subwoofer
Epson r 285
Greetings,
There is a Vista driver for your printer. Here is the link.
You just need to visit http://esupport.epson-europe.com/
NOTE: Identify your Vista version first
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Office Equipment & Supplies
Having trouble setting up sound system
I can see by the setup of this device, it can be confusing. So let's make sure you are setting the device to the correct "A" speaker outputs. These would all be on the rear panel, on the right side of the receiver. Is this correctly setup?
May 26, 2008 | Marantz SR-7200 Receiver
Sanaui
This is a device which gives the illusion of more spacious sound by adding reverberation (echo) to the audio signal. This particular unit uses a mechanical analog delay mechanism employing a steel spring! Analog spring reverb units enjoyed some popularity in the late 60's and early 70's, with the Sansui and Pioneer units being the most common..
Feb 12, 2008 | Audio Players & Recorders
Peavey PRO-12 (00497070) Main / Stereo Speaker Logo
137 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
