Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Generic problem for all Deep Fryers
Light does not come on, nor does it heat up
jam1254 on Nov 14, 2008
I've only used this heating element a few times. I removed the oil and cleaned the oil container and now the unit won't come. I checked the outet I was using and it is ok.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Nov 26, 2008
-   Mine is Imperial IFST-25 and I have the same problem. After cleaning with warm water, light does not come on. I lift it up about an inch and put down and sometimes it starts again. -   ranchburger9
Solution #1
posted on Dec 15, 2008
Not Rated)
bperi55
Rank: Apprentice
Rating: 100%, 1 votes
Some fryers have safety switches on the heating element, this is so they can not be turned on when not properly installed into the unit. Check to see if there are grooves or slots on the side of the fryer which correspond to grooves or slots on heating element. Then slide the heating element into the slots on the fryer.
Safety switch in most cases can not be seen and can not be disengaged by hand. The heating element must be installed properly in order to work. It may be illustrated clearly in the owners manual.
Do not try this with out oil in the Fryer!!
Was this helpful?
Yes
No
Related Problems
pilot light will light but fryer wont fire up
when i light my fryer it lights like it should but after...
When checking for resistance at sensor fryer probes, at 350*...
What should the resistance be at the thermostat at 350*?...
Can you Help with these Deep Fryer problems?
Owned less than 1 month and just...
Solve
My product is less than 1 month old. I plugged it in, it came on, started heating and then just... (More)
I have an old set of cast iron...
Solve
I have an old set of cast iron cookware and need replacement handles. The handles are wooden, have a... (More)
how to set temperature on a hobart...
Solve
how to set temperature on a hobart electric gas fryer
when you plug it in both lights come...
Solve
when you plug it in both lights come on but oil won't get hot
Sponsored Links
Describe your Appliance problem:
Select a Category:
Top Deep Fryer Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Deep Fryer Experts
Top Small Appliance Repair
(800) 341-6361
Mr. Appliance Corporation is one of the largest...
Mr. Appliance
(866) 895-9295
Rest assured, when you place an order for parts it...
Easy Appliance Parts
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
