Question about Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
The top compartment stopped putting out refrigeration. I cleaned the bottom grid. I vacuumed there, and pulled out the grid and cleaned and reinstalled the panel.
I thru out the food in the top compartment and I am unsure what to do next.
  • BORZOI Dec 26, 2008
    My kenmore elite 596 73503201 is not cooling in the refrigerator top section. The "SmartSeal" on the left door is very hot and there was a burning odor the first day it stopped working. It looks like an electrical component problem within the left door and/or "SmartSeal" section of the left door. Any help would be greatly appreciated.
  • moverMark Apr 07, 2009
    My Kenmore Elite, bottom freezer just had the same problem. Bottom freezer is working fine but the top fridge is not cool. The smart seal is very warm to the touch. It Seems like cool air is coming up thru the vents from the freezer compartment. We got this used and have just had it a week. It was working fine. I rolled it out from the wall to hook up the water supply. Right after I put it back it developed the problem. Can't figure how that would be related. I carefully removed the smartSeal and disconected the electrical connector and reinstalled the (now electrically disabled) smartseal. That may have been enough heat to defeat the normal cooling. We'll see how that works....overnight - maybe minor improvment. Next quess is the fan that moves cold air up is malfunctioning.
2 Suggested Answers
  • 320 Answers
SOURCE: kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Posted on Mar 27, 2009
I have a Kenmore Elite side by side refrigerator, the problem is the unit is not cooling at the top area of both the freezer and refrierator? the bottom areas are OK, I notice there is no air flow in the...
Is your fan inside the freezer compartment back wall towards the bottom is working. (Evaporator fan motor) ?
No fan... No circulation.
Fan may have failed or another common thing is failed defrost system has clogged up the evaporator coil and fan blade with frost. In this latter case, you will see white frost build up in the freezer back wall towards the bottom in freezer compartment.
Better call a local service technician. Little bit technical and hands on job.
Oct 23, 2017 | Kenmore Refrigerators
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Kenmore Elite 795.75542401 Water freezes on the bottom & then spills out to the floor. We can't find a drain hole anywhere!!
There is the drain in the freezer under the evaporator. You have to remove the rear panel in the freezer and the freezer floor to access it. Defrost it using a hair dryer and put hot water through the drain to make sure it's clean. Make sure the bottom end of the drain hose (behind the rear cover) is clean as well. Vacuum everything in the compressor compartment and keep it clean.
Please check the useful links bellow related to your query...
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itleaks
http://www.ehow.com/about_6736707_water-freeze-floor-bottom-freezer_.html
http://www.ehow.com/how_2208484_that-leaks-water-down-refrigerator.html
Let us know if you want something else please accept the solution.
Sep 20, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fan blade broken.
Mar 27, 2009 | Refrigerators
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
May 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
