General Electric Washer
The washer continues to fill with water until manually shut off. Model # WDSR2080DAWN. Serial # FL 177649G. Please help, I am tires of using all my towels to clean up my floor.
Glen
  • MacStang13 Nov 16, 2008
    Thank you for the incite on this problem.
  • 5,911 Answers
This problem is commonly caused by a pressure switch malfunction. This switch is located behind the water level or load size selector knob inside the operator console. If you remove the back of the console you will be able to access the switch. The pressure switch has some electrical connections and an air hose attached to it. The air hose runs from the switch to the bottom side of the wash tub. Air pressure from the tub increases as the tub fills with water and, depending on the water level selected, determines WHEN the water shuts off. Now...commonly what happens is the air hose comes loose from the pressure switch and it will no longer shut off. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
I would check the air hose, first. Often, all that is required is to reattach the hose and the problem is solved. However, if the air hose is intact and has no leaks or splits anywhere, I would recommend replacing the pressure switch. A replacment can be purchased online at searspartsdirect.com. Just type in your model number and look under the "Controls and Backsplash" heading for item number 10 (part #WH12X10065). Repairclinic.com also carries the same part for slightly less (item number 2205).
This is a simple repair (even if you have to replace the switch) and won't cost much. I hope this helps you. Let me know if you require additional assistance.
Posted on Nov 14, 2008
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
GETTING AN ERROR MESSAGE OF FL, WHAT DOES THIS MEAN?
This means that your Washer has somehow Over Filled with water and will "FL"ood if it does not drain the excess water:
It should also be beeping every 10 seconds and the pump should start to empty some water to rectify the issue.
Restart the machine machine as required or push the overfill reset switch.
To avoid flooding, you might need to temporarily shut the water supply if water continues to flow in the machine while the "FL" code is displayed.
Hope it helps let me know how you go.
Sep 28, 2010 | Kenmore Elite 21082
Fl error on washer
Hello there :
I am hoping that i am reading this right it looks like you said a fl error right and if so please read this whole solution that i have provided below
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
If this condition continues have the machines water level switch replaced or repaired
Hope this is very helpful for you
Best regards Michael
Feb 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
I have a calypso with an error code of FL. where do I find the switch to reset the washer
"FL" (Over Fill) flashes
The washer will beep every 10 seconds with no time-out, The
faucets to the inlet hoses if water continues to flow,
If it still happens you need to get a service guy out.
Dec 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer continues to fill after full, then spills all over floor until manual shut off
This is an indication of a pressure switch malfunction. Post back with your washer brand name and model number and I can tell you how to check it.
Feb 23, 2008 | Washing Machines
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
