Question about HP Pavilion zt1170 Notebook
Connection to laptop
How to connect to wireless network?
  • 903 Answers
If you have wireless capabilities on your laptop, then turn it on and right click the internet icon in your system tray (it should be crossed out to show that you have no connection), click on connect to network and it will show you all networks available. If your wireless router is up and running then this should show your network. Click on your network then click on connect. It will ask you for the password or the wpa key which will be the password that you generated for your network when you set up your wireless router. Type your password in then click ok, then you should be on the net. If your laptop does not have wireless capabilities then buy a wireless adapter and plug it into your usb port download the software that came with the wireless adapter then follow the same instructions above to access your wireless connection.
I hope this helps
Posted on Nov 14, 2008
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
How can I connect my notebook to another pc without installing LAN??
A Local Area Connection, or LAN, is generally a small home or office network used to link all the devices in the area. With the advent of wireless technologies, LAN networks are no longer limited to the amount of cords you own. Laptops can connect to wireless LAN easily with their built in wireless adapters. Connecting two laptops together over wireless LAN is also easy, but requires a few special steps to give the laptops access to each other.
1Connect both laptops to the wireless network you wish to use. Once connected, click the "Start" button and navigate to the "Network" menu.
2.Click the "Network and Sharing Center" link. Press the "View Computers and Devices" button. A list of devices currently on the network is displayed.
3.Check the list for the names of both laptops. If both laptops are displayed in the list of devices connected to the network, the devices are connected wirelessly to a LAN network.
Sep 06, 2011 | IBM ThinkPad R50e Notebook
Have a medion laptop that wont connect wireless
click on start >> go to control panel >> double click on network and internet connections >> right click on wireless network connection >> click on properties and go to wireless tab >> check the box at the top that says use windows utility >> click on ok and than right click on wireless network connection and click view available wireless networks. It will show you your network name. click and connect to your network.
Feb 26, 2010 | Medion md40298 Notebook
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Can't connect to netwoork
Just configure the wireless settings your laptop. Go to Network Connections > Right-click on Wireless Network > Properties. Go to Wireless Network tab and look for Preferred Networks. Just remove all of them and click OK.
Now, On the Network Connections, right-click on Wireless Network Connection > View Available Wireless Networks. Connect to your own wireless network and enter your wireless network key if it tells you to type it. That should fix your wireless connection. Now if your wireless network is not showing, you need to change the wireless channel of your router by accessing the router's setup page using your wired computer.
Apr 18, 2009 | NetGear WGR614 Wireless Router
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
No internet access
Check if the wireless network is connected properly in the laptop, try to disconnect the connection , and reconnect again ..if you still feel you are connected..at the lower right hand corner you will find the wireless network connection icon..right click the icon and click view available wireless networks, check you are connected..if yes click change the order of the preffered networksand remove your wireless network and then try connecting it..try it out and let me know...all the best
Jul 29, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
HP Pavilion zt1170 Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
