Windows XP boots and opens folder in Windows Explorer
When I boot up my computer running Windows XP, a program folder opens in Windows Explorer. It happens to be C:Program FilesDell, but I doubt if that matters. I just have to close the window, but how do I prevent this from opening? It's a Dell Dimension 5100.
  • Lee Nov 16, 2008
    Nick, your advice appears to direct me to the correct help at Microsoft, where I read
    To resolve this issue, delete the DesktopProcess value from the following registry key:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
    When I check this item, there is no value set. Any other ideas?
    Novelist:
  • 93 Answers
Here are instructions on how to fix this, directly from Microsoft. You are not the only person who has been baffled by this little gem. Here's the link on their website:
http://support.microsoft.com/default.aspx?scid=KB;EN-US;q228502
A note: Microsoft advises that when you go to change the registry, you be careful, and that is very good advice.
Cheers
Nick
Posted on Nov 14, 2008
  • Nick Nicholson
    Nick Nicholson Nov 16, 2008
    Two things additionally:
    1) Check your startup folder and make sure nothing is in there opening up that folder, and
    2) go to START > RUN > MSCONFIG
    Look in the startup section, and remove anything that is related to explorer. This is where a lot of your taskbar apps load, as well as a lot of unnecessary things. If you see something you aren't using, uncheck the box and it won't load on restart. As with everything XP related, be careful about what you disable. If you aren't certain what something is, then leave it alone. After you are done making changes, you'll have to reboot for them to take effect.
    Cheers
Slow opening of websites
How to Make Windows XP Startup Faster
Steps
1.Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
2.Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
3.Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
4.Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
5.Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation
After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally. However, Hibernation is a good long-term solution, as it does not waste electricity.
1.Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
2.Click on the box that says "Enable hibernation" to check it.
3.Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
4.Restart your computer every week or so to clear your computer.
The power can then be completely turned off, even at the socket so that no power is wasted.
Prefetch
1.Simply browse to the windows folder (Ex: C:Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:windowsprefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementPrefetchParameters
Under this key you should see a value named: EnablePrefetcher
It has 4 possible values:
0- Disabled : The prefetch system is turned off.
1- Application : The prefetch only caches applications.
2- Boot : The prefetch only caches boot system files.
3- All : The prefetch caches boot, and application files.
We don't want to disable it entirely. This would actually make boot times *longer*. This is because this feature is also used to speed up the loading of boot files. That is why we are going to pick the number 2 option. It allows us to keep the advantage of caching system files, without continually clogging the system up with applications.
Set the value to 2 and reboot.
The 2nd time you boot it should boot much faster. Remember that the side effect is that launching individual applications once windows has loaded will now be slightly slower.
Tips
When installing new software choose not to add the program to the startup folder.
. Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
. If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
. Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
. uncheck system startup unnecessary startup programs*
Warnings
. Save any open work before making changes.
. Shut down all applications before making changes.
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.Remove all toolbar from add or remove program. From control panel. Reset web settings from internet option.
Apr 14, 2012 | Microsoft Windows XP Home Edition English...
Tip
How to Make Windows XP Startup Faster Steps 1.Click on Start, then Run, and type...
Steps
Hibernation
Prefetch
Tips
Warnings
on Feb 25, 2011 | Computers & Internet
Tip
MultiBoot USB Flash - Survival Guide
Grub4DOS is a boot manager
that can be easily installed to a USB flash.
It allows booting multiple operating systems
from a simple graphical user interface.
1.) Format the USB flash drive in the FAT32 or NTFS filesystem. (Windows)
Download and start HPUSBFW.EXE )http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
-REMINDER!!! all data will be deleted on the USB flash-
1.a) Download necessary files
Grub4Doshttp://dl.dropbox.com/u/4040651/grub4dos-0.4.4.zip
Grub4Dos gui Installer 1.1
http://dl.dropbox.com/u/4040651/Grub4Dos%20gui%20Installer%201.1.rar
1.b) Extract the downloaded zip files into separate folders.
For example:
Grub4DOS to C:Grub4DOS
Grub4Dos gui Installer 1.1 to C:
2.)
If your flashdrive is not already plugged into the computer, plug it in now.
2.a) The next step is to run the Grub4DOS Installer.
Browse to the Installer's unzipped folder using Windows Explorer.
2.b) Run the grubinst_gui.exe program (Windows XP)
Right-click on grubinst_gui.exe Run as administrator (Windows 7)
2.c) Once the program is started, select the Disk option,
then click the Disk Refresh button and then select
your flashdrive from the dropdown box.
IMPORTANT:If you accidentally select the wrong drive,
you may not be able to boot your system without doing a boot repair.
2.d) Now click the Part List Refresh button,
then the dropdown box and finally select the Whole disk (MBR) option
2.e) Click the Install button to install Grub4DOS to the MBR
of the flashdrive.
Hopefully, you'll get the message that the installation was successful.
3.) The next step is to copy the grldr file to the flashdrive's
root folder.Using Windows Explorer, browse to the folder
where you unzipped
the Grub4DOS program and copy the file to the flashdrive.
3.a) Grub4DOS is now installed on the flashdrive.
4.)Download file
menu.lsthttp://dl.dropbox.com/u/4040651/menu.lst
4.a)You need to copy the menu.lst file to USB Flash
4.b)Create a folder Boot on a USB flash drive.
in this folder create new folders
Splash
menus
4.c) Download file
Snaiyahttp://dl.dropbox.com/u/4040651/Snaiya
4.d) On USB flash-open the folder Boot
Within-we see Splash folder. Copy the file Snaiya into it.
5.) Add Puppy Linux on a multiboot USB flash
5.a) Download the Puppy ISO imagehttp://www.puppylinux.org/
5.b) Create a folder Puppy on a USB flash drive.
5.c) Take from the downloaded ISO, file
PUP_420.SFS (from the folder Puppy)
Rename it to pup_420.sfs
and copy it to
USB flash.
5.d) Copy all other files from the downloaded ISO (from the folder Puppy)
to the folder /Boot/Puppy/ (Create a folder on a USB flash)
5.e) In the menu.lst add a:
title Puppy
kernel (hd0,0)/boot/Puppy/vmlinuz ramdisk_size=100000
initrd /boot/Puppy/initrd.gz
5.f) Preserve the changes and now menu.lst looks like this:
gfxmenu (hd0,0)/boot/Splash/Snaiya
timeout 30
default 0
title Puppy
title Boot from CD-rom
cdrom --init
map --hook
chainloader (cd0)
title ShutDown PC
halt
title Reboot PC
reboot
5.g) Puppy on our MultibootUSB flash-is ready for operation.
(Now we can restart our computer and see how it looks and works)
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
on Feb 07, 2011 | Computers & Internet
My laptop is running slow
Steps
Hibernation
Prefetch
Tips
Warnings
Apr 05, 2012 | Lenovo Computers & Internet
There is a listing available somewhere in Windows wherein you can "quick launch" a program to have it mostly loaded when first turning on the computer ( or have the program deleted from such...
A program can not be 'mostly [or partly] loaded' actually. You can go into the program's settings though and see if there's a way for it to 'Run on Startup', which would load the program when your computer boots up. The only problem with this is that it can slow your computer down and make it take longer to boot up.
Aug 21, 2011 | Computers & Internet
Tip
Steps to remove Windows 7 without affecting saved files or data: 1. Boot up and...
<span> <p>To format your hard disk during Windows 7 <a href="http://www.whitecanyon.com/how-to-format-computer.php#">installation</a>, you'll need to start, or boot, your computer using the Windows 7 installation disc or USB flash drive.<br /> <ol> <li>Turn on your computer so that Windows starts normally, insert the Windows 7 installation disc or USB flash drive, and then shut down your computer.<br /><br /></li> <li>Restart your computer.<br /><br /></li> <li>Press any key when prompted, and then follow the instructions that appear.<br /><br /></li> <li>On the <b>Install Windows</b> page, enter your language and other preferences, and then click <b>Next</b>.<br /> <ul> <li>If the <b>Install Windows</b> page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see <a href="http://windows.microsoft.com/en-us/windows7/Start-your-computer-from-a-Windows-7-installation-disc-or-USB-flash-drive">Start your computer from a Windows 7 installation disc or US</a></li> <li><a href="http://windows.microsoft.com/en-us/windows7/Start-your-computer-from-a-Windows-7-installation-disc-or-USB-flash-drive">flash drive</a>.</li></ul></li> <li>On the <b>Please read the license terms</b> page, if you accept</li></ol> <ol> <li> the license terms, click <b>I accept the license terms</b>, and then click <b>Next</b>.<br /><br /></li> <li>On the <b>Which type of installation do you want?</b> page, click <b>Custom</b>.<br /><br /></li> <li>On the <b>Where do you want to install Windows?</b> page, click <b>Drive options (advanced)</b>.<br /><br /></li> <li>Click the partition that you want to format and click <b>Format</b>.</li> <li> <ul> <li>If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the <b>Delete</b> option for each partition. Once you have deleted all of the partitions, select thepartition and click <b>Format</b>.</li> <li><br /></li></ul></li> <li>Pick the formatting option that you want.<br /><br /></li> <li>When you've finished formatting, click <b>Next</b>.<br /><br /></li> <li>Follow the instructions to finish installing Windows 7, which include naming your computer and setting up an initial user account.<br /> <ul> <li>If you do not want to reinstall Windows 7, you can cancel the installation at this point and keep your newly formatted drives.</li></ul></li></ol></span>
on Nov 25, 2010 | Computers & Internet
How can i remove microsoft windows 2000 form a dual boot system
Just start windows XP. Open Explorer go to menu: Tools - Folder Options Select : View Tab Select : Show hidden files and folders Click OK In explorer select C;\ Look for file : boot.ini Open boot.ini for editing (double click) CAREFULLY remove the line which looks like : multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" Close notepad, select SAVE Reboot You will not have the option to start windows 2000 anymore. On your desktop right click: My Computer and choose "manage" Select: Disk Management Select the partition where Windows 2000 was (is) installed. Right click and choose format You can now use this partition to store data and or programs
Feb 01, 2011 | Microsoft Windows XP Professional
Not compatable with windows 7
Hello
OK, please be more specific on the exact question or problem you are experiencing.
Kind regards
Andrea
Nov 26, 2010 | Computers & Internet
Hi everyone, I would just like to know, does anyone know how I can obtain or create an emergency boot up disk for windows xp home edition? Many thanks. Andrew
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
Jan 15, 2010 | Computers & Internet
Error 1335. The Cabinet file Data1.cab required for this installation is corrupt and cannot be used.
When you try to install Microsoft Office 2000 or Microsoft Office XP, you may receive the following error message: Error 1335-Cannot copy cab file Office1.cab. The file may be corrupt. When you start the computer in Safe Mode and then try to install Office, you may receive the following error message: The Windows Installer Service could not be accessed. This can occur if you are running Windows in Safe mode or if the Windows Installer is not correctly installed. You may receive this error message even when the Office CD-ROM package works correctly on another computer.
When you try to install Office while you are logged on to the computer with administrative rights, you receive the same error messages. uparrow.gifBack to the top CAUSEThis error can be caused by dirty media, CD-ROM read issues, or problems with me... loadTOCNode(1, 'cause'); This error can be caused by dirty media, CD-ROM read issues, or problems with memory allocation. uparrow.gifBack to the top WORKAROUNDTo work around this problem, try the following methods. Method 1: Clean the CD-... loadTOCNode(1, 'workaround'); To work around this problem, try the following methods. uparrow.gifBack to the top Method 1: Clean the CD-ROM loadTOCNode(2, 'workaround'); Use a soft cloth to gently clean the disc. uparrow.gifBack to the top Method 2: Change the memory settings for installation loadTOCNode(2, 'workaround'); To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
uparrow.gifBack to the top Method 3: Install Office by using a flat folder loadTOCNode(2, 'workaround'); To install Office by using a flat folder, follow these steps:
  1. Clean boot your computer. For additional information about how to clean boot Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 310353 (http://support.microsoft.com/kb/310353/ ) How to perform a clean boot in Windows XP
  2. Save a copy of the Microsoft Office CD-ROM to your computer's hard disk. To do this, follow these steps:
    1. Start Microsoft Windows Explorer. To do this, right-click Start, and then click Explore.
    2. Create a new folder at the root of a hard disk volume, and then name it "Flatfile" (for example, C:\Flatfile).
    3. Locate the drive that contains the Microsoft Office CD-ROM, and then copy all the contents of the Microsoft Office CD-ROM into the C:\Flatfile folder. To do this, follow these steps:
      1. In Windows Explorer, click the CD-ROM icon (or DVD-ROM icon) that contains the Microsoft Office CD-ROM.
      2. On the Edit menu, click Select All.
      3. Paste all the files into the new folder. To do this, drag the selected items on the right side of the Explorer window into the C:\Flatfile folder on the left.
        Note If you receive the "This Folder contains "X" hidden files" error message, follow these steps:
        1. On the Tools menu, click Folder Options.
        2. Click the View tab.
        3. Turn on Show Hidden Files and Folders.
        4. Turn off Hide Protected Operating System Files.
        5. Click Apply, and then click Ok.
        Note If there are errors during the copy process, this can indicate problems with the CD-ROM (media), a dirty CD-ROM drive, or a problem with your hard disk.
  3. Restart your computer the way that you typically do, and then install Microsoft Office from the C:\Flatfile folder onto your hard disk.
uparrow.gifBack to the top Method 4: Install only one Office program loadTOCNode(2, 'workaround'); Install only one Office program, such as Microsoft Access. To do this, select a Custom install, and then cancel the selection for all but one of the Office programs. If the Setup program is completed successfully, restart the Setup program. Restarting the Setup program will take you into Maintenance mode. Click Add/Remove Programs, and then click the programs that you did not install in the first installation of Office. uparrow.gifBack to the top Method 5: Contact Microsoft loadTOCNode(2, 'workaround'); If the previous methods do not resolve the problem, contact Microsoft. For information about how to contact Microsoft, visit the following Microsoft Web site: http://support.microsoft.com (http://support.microsoft.com/) uparrow.gifBack to the top APPLIES TO
  • Microsoft Office XP (Setup), when used with:
    • Microsoft Windows XP Professional
    • Microsoft Windows XP Home Edition
  • Microsoft Office 2000 Premium Edition
  • Microsoft Office 2000 Professional Edition
  • Microsoft Office 2000 Standard Edition
  • Microsoft Office 2000 Small Business Edition
  • Microsoft Office 2000 Developer Edition
  • Microsoft Access 2002 Standard Edition
  • Microsoft Excel 2000 Standard Edition
  • Microsoft FrontPage 2000 Standard Edition
  • Microsoft Outlook 2000 Standard Edition
  • Microsoft PowerPoint 2000 Standard Edition
  • Microsoft Word 2000 Standard Edition
Sep 15, 2009 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
