Only half of the wicks burns/ flame varies in height/ smokes !
Looks like only the back side of the wick burns. I can't seem to adjust the flame height It's either too high or almost goes out, and when the flame is high enough to heat, it smokes like CRAZY !! Would appreciate ANY help. The heater has been used 1 season and has very few hours on it.
  • 345 Answers
Sounds like you have a wick that has burnt unevenly in the past and now there is not a good setting for an optimum burn. Either the wick needs to be trimmed even or you need a new wick.
Posted on Nov 14, 2008
How do I get my furnace to stop smoking and make my burner flame turn blue
This is an oil heater with a wick, or an oil furnace?
Wick
If it smokes the wick is too high and the burner is not burning all the gases produced by the hot oil in the wick.
Use the wick trimming tool and then relight it. Light the wick and then lower the flame until it is blue.
Furnace
With a furnace, you need to open the front, clean out any soot and clean the spinner in the middle. You may need to regulate the air mix intake to get a blue flame. If it is yellow, you need more air.
If it's gas, you need an engineer.
Feb 01, 2016 | Heating & Cooling
Put in new wick cleaned it up wait an hour lit it and it smokes any suggestions
new wicks in kerosene heaters will smoke till the mfg coating burns off it , burn it outside for a few hours then readjust wick height then it should stop smoking
Mar 11, 2015 | Heating & Cooling
Black smoke coming kerosene
hi dear,
First of all make sure that the heater is filled with K-1 Kerosene. Other fuel, such as gasoline, home heating oil, etc. do not burn hot, causing the heater to burn out of control. NEVER USE GASOLINE or any other fuel described as flammable. If there is any question about the fuel in your heater it is best to drain it and replace the wick and start with fresh K-1 Kerosene. If you are sure of your kerosene and your heater is giving off sooty black smoke it is a sign that the fuel/air mix is off. Make sure your heater is not in a draft. Too much air can create a very high flame condition. Avoid placing the heater in drafty areas or under a ceiling fan. Make sure the burner chimney is seated correctly. If the burner chimney didn't seat into place correctly after lighting you may be getting a very high flame on one side. If it's a high orange flame all the way around try rolling the wick adjuster knob down within the adjustment range - the wick may just be raised too high. If these things do not fix the problem wait until the heater is cool and inspect the burner cylinder. If there are any holes plugged with soot it needs to be cleaned, or if it's dented or buckled it needs to be replaced. After you have checked the fuel and burner you should check to make sure the wick is installed at the correct height. Refer to the owner's manual for exact wick height. If the wick is installed correctly and there is no other obvious defect it is best to take the heater to a service center to determine the cause. Our Find a Retailer tool can be used to help find a servicing center.
Jan 04, 2014 | Corona 23-DK Compact Heater
Dyna glo RMC 95 C6 kerosene heater, BRAND NEW. Wick and flame seem very low. At Max the wick height is 3/8(suggested height by manufacturer), flame is quite low, and not very hot at all
1. Check to make sure you using fresh clean kerosene fuel. 2. Make sure you fill the heater and let it set for at least an hour, 2 hours is better. 3. If either of those solutions don't fix the problem, return to the store.
I have the same heater and just changed the wick. When working correctly, it should be so hot that it's uncomfortable to hold your hand 2 feet over it.
Jan 01, 2011 | Heating & Cooling
Where can I find an Owner's manual for an Everglow Kerosene Heater or in structions on how to install the wick and burner.
First you need to get the shell off the unit, and get down to the main burner area. There should be 4 wing nuts holding the wick tower down to the fuel tank. These must be removed, and the wick and the adjuster apparatus removed up and over the top of the center tower. Having a towel or old rag handy to set the unit on when you get it off is a good idea, so you can work on it. Remove the old wick, taking care to see how the fabric band on the cloth wick is positioned on the bottom edge of the wick carrier band. Install the new wick at the same level as the old one on the carrier and set it aside. Make sure you clean the tower, especially all the black carbon buildup around the center and near the top. I use a wire brush on a cordless drill to buff the stuff off, works great. Remove the old kerosene from the tank and clean the tank best you can, then put the new wick inside the carrier, down on the tower, being careful to get the bottom portion of the wick down into the tank area, (it should be quite loose down there once you get the rest of the carrier on the tower. Make sure the whole apparatus sets down evenly and fairly easily on the bottom tank part and screw it down with the four wing nuts. I use a paper cup to pour clear, K1 kerosene onto the new wick all the way around the tower, then make sure it moves easily up and down with the height adjuster knob and while it's in a down position, pour some more kero in on it. You can pour several cups of kero on the new wick and then when it's working up and down well, turn it up and lite it before you put the whole thing all back together. It's best to do this outside as sometimes you can get smoking, if you don't get the flame spreader cage on quickly enough. Once it's on and the flames come up and look good, then turn it off, let it all cool off and you can put it back together. Remember, don't use anything but absolutely clean, clear, K1 Kerosene in the unit and burn it completely dry at least once a week, if you use it a lot. It's called dry burning, and it's a wick cleaning function. If you do this, the wick can last years and years.
Feb 21, 2010 | Grilling
Changed wick in corona 23dk , now has very high flame and smokes like crazy.
the wick is round in this heater and may have to be cut for height. should be about an eigth of an inch below the top
Jan 11, 2010 | Corona 23-DK Compact Heater
My Dyna GLo kerosene heater has excessive smoke and yellow flame
I'm wondering the same
Should a duraheat, etc., cylindrical convetion heater's flame be bright yellow, blue , or what? With the old wick the flame was blue, with the catalytic converter glowing red hot. Now with the new wick, I can't even see the CC, because the flame burns a bright yellow. Also I have to really fine tune it now. A wee bit too high, I get smoke and soot. A wee bit too low, same...smoke and possibly flame out.
Feb 24, 2009 | Heating & Cooling
Burns unevenly and smokes
try emptying your heater of fuel,and lighting it letting burn for several hours. This will burn all of the deposits off of the wick. Make sure your heater is outside when you do this. when done lower the wick,fill with fuel,and let the wick soak for fifteen minutes before lighting.If this doesn't work try brushing the top of the wick a light brush of some sort and light.If still no luck,change the wick.
Oct 01, 2008 | Corona 23-DK Compact Heater
Dyna Glo 95-c flame height
check your air passages for a blockage. the wick just aids in burning your fire.
Nov 03, 2007 | Heating & Cooling
Heating & Cooling Logo
343 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
