Question about Linksys Wireless-G WRT54G Router
Device Ownership Password
Trying to connect another computer to my security enabled wireless network through a D-Link wireless router (DIR-615) and I'm prompted for a 'Device Ownership Password'. It's not a password that I use, so I'm not sure what it's asking for... it apparently consists of 6 numbers, and the prompt indicates that I should be able to find it on the device, but there's nothing that would fit this password criteria.
Is there a default password? If not, how can I figure out from the back end of my current connection with the original laptop (Dell XPS M1330, Windows Vista)?
HELP!!!!
  • 4 more comments
  • Bathtoy Nov 26, 2008
    I have a similar problem..... resetting the default settings on the router doesn't hep. that simply allows you to connect a "first device" (laptop) to the router. To connect an additional laptop you need it's "Device ownership password" which is a six digit number and nowhere to be found. It's a Fujitsu/Siemens Amilo M7400. any help would be appreciated.
  • Anonymous Feb 14, 2009
    Yea but if I am in a public Coffee House and they say their network is not password protected, what do I do? I can't get this off the router.
  • Paras Tolani Sep 30, 2013
    Control Panel -> Add/Remove Programs (or Programs and Features) -> Intel(R) PROSet/Wireless Software -> Modify -> Then UNcheck Wi-Fi Protected Setup.
  • Anonymous Nov 28, 2013
    Dont worry you all call here any time to fix this problem toll free number 1-855-219-3333
    dont worry you all for any help regarding router call here toll free 1-855-219-3333
Control Panel->add or remove programs-> Intel(R) PROSet/Wireless Software -> Modify -> Unmarked WI-FI PROTECTED SETUP
Posted on Dec 02, 2008
  • gill_newsome
    gill_newsome Aug 15, 2012
    On joy! success. You are a star.
  • Robert Walker
    Robert Walker Feb 27, 2013
    This is the solution! Thank you so much!
Device ownership password:
Posted on Dec 17, 2008
  • bigdrewbowsk Dec 27, 2010
    You freaking rule!!!!! It took us 2 hours and we found your notes. We are in
The D-link has an 8 digit numeric PIN code on the label near the UPC code. This is what you want.
Posted on Feb 04, 2009
    Scholar:
  • 69 Answers
The default password is found near the upc symbol on the router. That said i find it easier to reset the router before i reconfigure it. You can do this with a pen. on the back you will find a small hole. Put the pen in there and hold for thirty seconds and voila its reset to factory settings.
hope this helps
Posted on Nov 14, 2008
The LINKYS WRT310N has an 8 digit numeric PIN code (exclude the dash) on the labelbelow the MAC Addess under the router. This is what you need to enter.
Posted on Jan 24, 2010
Hey, this might work, if ur laptop/desktop has an Intel-Based motherboard, it may also have an Intel ProSet Wireless Adapter/Chip.
Unfortunately, there's currently a bug causing it to conflict with the WPS (Wi-Fi Protected Setup) of the router. We just need to disable this (this is different from the Wireless Security/WEP/WPA).
After disabling this, refresh the wireless network, once the wireless device and router pair up, we can now re-enable the WPS of the router (or just leave it disabled).
Posted on Jun 08, 2010
    New Friend:
It seems like you have installed wireless pro card in your computer. so in this situation, you need to uninstall wireless card from control panel. once you will do that then you need to go ahead and restart your computer and try to connect your computer. it will start working fine. For more information you can visit link Tech Support. this will hep you alot.
Posted on Feb 22, 2015
  • 3 Answers
This is really owsome
Posted on May 15, 2011
  • 3 Answers
Disable the wps option in the router it will work
Posted on Sep 28, 2012
Forgotten pre-shared key for D-Link Router
I thought there was a check box in this model that enabled you to see the password/key. If not then you may have to do a factory reset and set-up everything from scratch. Cannot remember if this model has a guest mode, but if the device you are connecting is not critical, TV, BlueRay, Roku etc, then enable the guest mode without a password to connect. These devices will NOT connect to other things on the network, but if they only need internet access it may be OK.
Dec 30, 2011 | D-Link DIR-615 Router
I am connected to a DIR 615, it says I have wireless connection but it won't connect wireless, if I connect a cable it is fine??
Hi mike63771,
All you need to do is to set it up properly. Make sure that the router is connected to the computer using an ethernet cable so that the computer will be able to communicate with the router. Then open a browser type 192.168.0.1 on the address bar. The default username is admin and the password is blank. Go to the Wireless Settings Page then check the SSID or Network Name and the Network Key or Passphrase. Now try to connect to your computer. Click on Start then click on Connect To. Select your Network Name then if it ask you to enter a password enter the Network Key. You can personalize the network key on the router settings page.
Rate me if this helps so i can help other.
Thanks for using Fixya.
Feb 02, 2011 | D-Link DIR-615 Wireless Router
I am trying to connect my ipod touch to wireless dlink dir 615, but I need a password. How do I get the password
When you configure the "wireless" adapter inside the D-Link router, you should set:
* an SSID (a name for your wireless network)
* an encryption-level - hint: use 'WPA'
* a password for your wireless network
Once you've done the configuration, use the SSID/password on your iPod Touch.
Jan 10, 2011 | D-Link DIR-615 Wireless Router
What is the Device Ownership Password
Device ownership password will be located at the bottom of the router. when you autoconfigure security for your wireless router the router uses the device ownership code as the password
Dec 24, 2010 | D-Link DIR-615 Wireless Router
I have a DIR-615 router and can not locate the device ownership password. It is not on the label beneath the MAC address. Any ideas?
This Device Ownership password is actually reffering to the WPS PIN number of your router which is usually on the sticker on the device. If you can't see it anywhere on the device, scan for wireless networks and connect to your network.
Once it will ask for the device Ownership password again, just click on the phrase that says " I want to enter a network key or passphrase instead" or " I don't want to configure, I just want to connect" ( this is applicable with vista ). If you have an XP computer and your using the wireless utility of your computer, disable that utility and use the Windows Zero Configuration.
Sep 18, 2010 | Linksys Wireless-G WRT54G Router
How do I set encryption/password on DIR-615// Many Thanks, Steve Pfeiffer tunemxrgmail.com
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Aug 30, 2010 | D-Link DIR-615 Wireless Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
How to secure network for DIR 615 so it can't be used by someone in the neighbourhood. When I type in the PIN # that came with router it says it is unsuccessful
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 07, 2010 | D-Link DIR-615 Wireless Router
Need security encryption code for dir 615
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You will need to check the wireless settings of the router .
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 01, 2009 | D-Link DIR-615 Wireless Router
Cannot connect MacBook to DIR-615 router
Is your wireless network secured ?
If you are trying to connect to the secured wireless network, make sure that the network that you are typing is correct.
If you are not sure about the network key
then check the network key on the router.
You said that MAC is able to connect to the neighbor's wireless network.
Make sure that the Wireless MAC filter on your router is disabled.
Click here to know more about network key
Oct 06, 2009 | D-Link DIR-615 Wireless Router
Linksys Wireless-G WRT54G Router Logo
58,834 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
