Tps reads 2.5 volts at around 51 percent
1) Maladjusted TPS
2) Defective TPS
3) No +5 volt reference to TPS
4) TPS-return to ECM is shorted to ground or to sensor ground
5) Defective ECM
Good luck, i hope this helps.
ok here is a update the iac was really dirty so i cleaned it nd cleared the codes then ran it it popped a po122 so as soon as weather clears up i will do all my volt ohm meter checks and repost.
base idle was out of adjustment and the idle air controller is unserviceable idle sticking at 1100 to 2100 rpm then down to 750 rpms and tps was not installed properly and arm inside was bent have tested all sensors iac would not respond to functional test with mtg 2500 scan tool . I also found a mouses nest in the air box which covered the pcm which i cleaned out but i wonder if it was overheating the pcm by being insulated by the nest thank you for your help i will keep posting my details and solutions.
ok replaced iac still geting hi idle but changes everytime i restart it then eventualy it drops to 750 but some times if i snap the throttle it will drop back down but only to 1100 then i can cut it off and restart it and then it will idle at 750 rpm no codes and no driveability problems.
ok found a cracked map replaced it still same problem unhooked iat sensor and and it calmed down then gradually climbed back up to 1500 ive checked every sensor wiggled every harness sprayed every where found no leaks no codes manifold vacum is 20 hg ran with maf unhooked went right to 2500 rpm air filter is clean checked my grounds and they are good any ideas.
ok this is solved the pcm posted no dtcs and in the proces of testing around the pcm and found numerous mechanical problems which were then fixed in the end the pcm was bad which was my initial diagnosis but it had a bad tps and iac as well as the upper intake being unservicable leaking coolant and vacum also the throttl body had to be removed and cleaned 6 hours later it was spotles i greatly appriceate all the help from the fixya members so i wanted to make sure i posted the solution for this problem .Douglas Bean.
