Question about HP Pavilion F1703 17" LCD Monitor
17" Monitor keeps going black
My monitor has a nasty habit of going out any time it feels like it, just like somone has switched a light off. It happens most of the time shortly after I start the computer but it has happened much later in the day. The off/on light remains on so I turn it off and on again and the screen lights up, for maybe 20 or 30 seconds, only to return to black shortly afterwards. It's an LCD and it's about 2YO. Would appreciate any help, Thanks for your time.
  • 47 Answers
Hi Rahni, It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Posted on Nov 18, 2006
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Speakers do not work. What am I not doing correctly to connect it to a dell dimension 8300 computer
Windows has a nasty habit of muting the sound. From the Speaker icon in the right bottom corner of the screen click on the speaker and unmute the sound.
Aug 28, 2010 | Mag Innovision LT765b 17" Flat Panel LCD...
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
17" Sony Monitor Goes Black and No Light Shows On The Switch
Sounds like your backlight bulbs are wearing out.It is a common problem with Sony LCDs. Difficult to replace then.
Monitor Mike
Jan 03, 2009 | Sony SDM-HS73P 17" LCD Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
Monitor Continually Goes Blank
You are right in assuming it to be the monitor.
It is the inverter circuit that powers the backlights inside the LCD.
No backllight, no view. If you shine a bright light into the screen you will see it is still working, just not visible.
The Viewsonic range of monitors have a habit after several years use developing bad capacitors that need to be replaced. It's something that happens to most LCD's and alot of other electronics.. so not a design flaw, just age.
If you have modest electrical knowledge then its an easy job, If not then take it to your local TV repairman and have them do it. It should not cost alot to have it done. The main expense in this case is the labour.
Call a few shops in the area and get rough quotes to have it done. You will be surprised how much the cost can vary for the same simple job.
Apr 21, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Help with my monitor
Hi .
If your monitor has a transformered type power supply EG 12 TO 24 VOLTS try another one they have a nasty habit of going faulty on nearly all makes that use this set up.
If its not that then it could be the inverter that has gone faulty.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | Samsung SyncMaster 205BW LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
108 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
