Question about Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120
Disabling onboard video on Acer aspire m1640
I cant find the option in bios, when i disable in device manager its just reloads when i reboot.
the card im tryin to install is xfx geforce 9800 gt
  • 1 more comment
  • dirtdog27 Nov 14, 2008
    where can i find this "graphics options"
    oh i found out the card needs minimum 400watts and mine only has 250 :(
    BIOS Type AMI (04/16/08)
  • Acer Master
  • 4,806 Answers
You cannot dissable the on-board graphics in the bios, in the graphic options you must choose which port you want to use, if you have a pci express card then chose pci as the primary graphics, press ok then F10 your pc will reboot and the on-board vga won't load up in windows
good luck
Posted on Nov 14, 2008
  • Lee Hodgson
    Lee Hodgson Nov 14, 2008
    please tell me your bios manufacturer and firmware version ad i can tell you
  • Lee Hodgson
    if you cant find the settings in the bios, go to device manager and disable the on board graphics (display adapters), reboot and that should solve your problem
Recently I bought the ATI SAPPHIRE Radeon HD 6770 flex edition on ebay. Today it arrived and I put it in my motherboard MCP73PV ( from oem pc Acer Aspire M3641) (also i have a new power suply 450 Watt so...
in the bios, there are usually settings for onboard devices. try turning off your onboard vga in the bios. and/or enabling/disabling pci-e video settings in the bios. it also helpful to ensure there is a monitor plugged into the video card. if there are 2 video outputs on the new card, try plugging the monitor into one, reboot, if nothing shows up, plug the monitor in the other one, reboot, if nothing shows up; i dont know :)
Sep 12, 2013 | Computers & Internet
Hi, excuse my poor english. How can I disable onboard video on a Lenovo M55e 9632AE2? Thanks in advance. Markus Brandl
There are two ways to disable the onboard video:
First Option:
When the machine boots up, watch for instructions such as "Press to enter setup, bios, configuration, ect." Within the BIOS setup should be an option to disable to onboard video. This can usually be found within an Integrated Chipset Features section or a Video section depending on your BIOS. Be careful though, messing with settings that you don't understand can affect your computer negatively.
Second Option:
Assuming you're disabling the onboard video because you have installed a video card, access the device manager by right-clicking "My Computer" and click Manage. Select the Device Manager on the navigation pane on the left, then expand the Display Adapters section. Right-click on your onboard graphics adapter and then click Disable and you're done!
May 25, 2011 | Lenovo ThinkCentre M55e 9632 PC Desktop
I have a acer aspire m1640, with the motherboard fails, if i can not fix it, what motherboard, acer apart, can i mount it? thank you
There are a few options you have on this, but if you want to maintain full compatibility with your current hardware, then you must purchase a motherboard that supports DDR2 533/667 MHz SDRAM since that is what comes standard in Acer Aspire M1640 Desktops.
A few options that would be similar to stock motherboard would be:
Foxconn G31MXP-K I7 or Biostar TForce TG31-A7
Those motherboards have similar specs to the stock motherboard and you can take a look at the specs of the Acer Aspire M1640 from this link below:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM1640/AspireM1640sp2.shtml
Both those motherboards I have linked you too are microATX boards, which should fit fine in your case which may be a standard ATX case.
If you are willing to upgrade your ram, then your options open up to any motherboard that supports the Intel Pentium Dual Core processor. Since the stock motherboard also provides onboard video, chances are you don't have a video card plugged into your motherboard (unless you've upgraded that yourself) which means you should also look for a motherboard that provides onboard video so you don't have to purchase a video card.
Feb 26, 2011 | Acer Aspire M1640 Refurbished Intel...
How do I disable onboard video for Acer M1641? There seems to be no option to do so in the bios and I cannot get a display on the new video card. Computer does post normal.
You say the computer posts normal--is the video card being recognized within Device Manager? Try installing by adding a new device, then everything should be fine. Also make sure that your monitor is plugged into the card :) . Try different connections to monitor if available.
Apr 12, 2010 | Acer Aspire M1641-U1521A PC Desktop
I need to disable the onboard video by finding the jumpers on the motherboard (MSI 7191 Version 1.1). When I installed a new PCI card (because the onboard video is broken) the computer freezes up and...
Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
Sep 06, 2009 | MSI PM8M-V Motherboard
Disable sound
When you start your computer, you can press a key to get into your bios setup. I can't remember what the key is in an Acer, but it may be the del key or perhaps the F2. In any case, it should tell you at the bottom of the screen which key to press.
Once in the bios, you should go to the advanced settings (if that is an option) and disable the onboard sound. If there is no "advanced" setting, then you will need to look around for that option.
You can always disable the sound in Windows by going into the device manager, find the sound card that is installed, and disable it.
Jan 31, 2009 | Acer Aspire 3100-1405 Notebook
Disabling Onboard Video
no you dont need the jumpers or some from there...just before booting your OS,go into the bios field.
there you will find the option you must set to disable.
the exact point youll find it I cant tell you because bios are different from board to board..depending of the manufacturer..just surf the bios,youll find it and disable it
good luck bye
Feb 07, 2008 | Biostar P4VMA-M Motherboard
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Pcmcia cards show up as mtd-0002
if you go into sound and multimedia you can change the preferred output/input items to your PCMCIA card rather than the onboard systems. you could also try disabling onboard systems in device manager too.
Oct 07, 2007 | Gateway 7210GX Notebook
Hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Apr 28, 2007 | HP Compaq dc5000 PC Desktop
Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120  Logo
1,643 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
