Question about Toshiba 32HL95 32 in. LCD TV/HD Combo
Toshiba 32hl66 how do i reset tv to factory setting I have a line through my screen and I was told I can rest it by using the remote or power button on the tv
  • 52 Answers
SOURCE: No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
Posted on May 30, 2007
SOURCE: Toshiba 32HL66 Audio completely out!!
you can search in ebay or other site try to do that and you may find it
Posted on May 30, 2009
alpug
  • 1961 Answers
SOURCE: I have a Toshiba 32AV600A which randomly scans
the solution for the problem is to reset the system.the reset button is located on the mainboard PCB..this is the only 1 switch found on the main board just press the switch twice and the system will be reset..to go to the mainboard remove the back cover of your tv and you can see the main board..
tnx hope this helps you.
please rate my help..
Posted on Jun 05, 2010
SOURCE: I have a Toshiba 40RV525U LCD TV. Wondering how to
my tv wont switch from 1080p to 720p while changing chanels. in order to watch 720p chanels I must turn off the tv and turn it back on, then the 720p chanel will come in. it will change back to 1080p if the chanel is changed to a 1080p chanel but not back to a 720p chanels.
Posted on Aug 25, 2010
welcomejee
  • 10594 Answers
SOURCE: have a toshiba 37av502r as
We just had chat session about this tv.
You can cancel this question or send an email to Customer Service of Fixya.com at following email address as they look after premium matters.
premium.support@fixya.com
Thanks.
Posted on Sep 12, 2010
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
Need information on a philips t.v. model 32PT6441/37
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 12, 2008 | Televison & Video
Have a vizio tv model e550va mfg date june 2010 serial no ltlpieal2500661. don't have the remote. there was a problem with my cable and I tried to use buttons on the side.
Try a hard reset on set and see if that does it. Also check with Vizio to see if there is some sort of factory default reset provision. Sometimes you can access it with some of the controls built into the set.
Apr 30, 2017 | Vizio Televison & Video
How do i do a factory rest
  • Debra try this to reset, do not use remote for this operation.
  • With the TV powered on complete the following steps:
  • Press and hold "Menu" button on the front of the TV
  • Press and release the "Power" button on the front of the TV.
  • Press and release the "Volume Down" button on the front of the TV.
  • This should bring up the service menu.
  • Using the buttons on the front of the TV, scroll down and select (Reset to Factory Defaults).
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Are You locked Out
Questions Answers for RCA reset to factory settings Projection Televisions
RCA D52W23 Troubleshooting Manual
Apr 26, 2016 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can i run a channel scan on a toshiba model number 32HL66 without a remote
You should be able to access all features with the menu button on the TV itself. You make selections on the menu with either the Volume or the Channel buttons. On screen instructions should guide you.
Nov 29, 2015 | Toshiba Televison & Video
My toshiba flatscreen says retail unlock on it an it wont do nothyn.. how i fix it without original remote
You can reset and eliminate the lock on some televisions without the remote.. Hold the power button for five seconds. The television will automatically restart. If the lock is still on, unplug the television and remove the battery from the back panel of the television. Wait several hours before reconnecting the plug and reattaching the battery.
You say you have a Universal remote. If you have not done so yet use the procedures that came with your remote to install it on your Toshiba. After using the install procedures you should at least be able to power on and off the TV.
power the TV on and then do the following:
TOSHIBA specific advertisements or "Retail Lock" at anytime when operating, perform the following procedure:
  1. Using the remote control, press 1, 2, 3, 4 in this order. This will release the "Retail Lock" mode.
  2. Perform a factory reset of the TV
  3. Resetting Factory Defaults:
To reset all settings and channels to their factory default values:
1 Press the MENU button and open the Installation menu.
2 Highlight Reset TV, and then press the ENTER button.
3 Enter your PIN code (If a PIN code has been set).
4 A con?rmation screen appears. Select Yes, and press the ENTER button. The TV will turn off automatically.
Then do the following:
  1. Power on the TV. You will be prompted to perform the first time setup.
  2. Be sure to set the Location option to Home.
  3. Continue with the first time setup.
The "Retail Lock" should be disabled and you can now use all the functions of the TV.
hope that helps
Jan 23, 2015 | RCA Televison & Video
Toshiba 32HL83 color line full screen
Some settings have got changed. Look for any jammed buttons on the remote control. Try removing the battery from the remote and try from control of the TV. Try resetting to factory default.
Aug 02, 2012 | Toshiba 32HL83 32 in. LCD HDTV
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to reset sharp aquos lc-32l400m?thanx before
Sharp Aquos LC-32L450M - i have recently baught this LCD, but I think the 'mpx' ie the multiplex sound is not working. there is this 'mpx' button on the remote, but wen i press it nothing really happens. in the manual its only written in one line "mpx- multiplex sound" . please any one can help me ..I m really not happy wit the sound right now. paid so much & no good sound its bit irritating please any one help.. wats the problem
Jan 06, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Toshiba 32HL95 32 in. LCD TV/HD Combo Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
