Question about HP Pavilion a305w (DM181AR) PC Desktop
Brightness quit working
My brightness box used to pop up randomly and fluctuate. I had to hold in the right arrow to have it go up to 100 but then it would just go back to 0 unless I kept holding it in and sometimes it would eventually go off. Now the buttons below the screen for the menu to get in to adjust brightness and contrast and such do not work at all. What can I do to get my brightness back? It's a real pain not being able to see anything. (The last time the box popped up it went down to 0 brightness and wouldn't let me put it back up to 100, so my computer has been stuck at 0 brightness for a good many months now...).
  • 300 Answers
Unfortunately, it soulds like the monitor may be going bad. You may have to use the manufacturer warranty if its still valid.
Thanks
Posted on Nov 15, 2008
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
Can you please help me. My aspire one acer netbook 10.1 inches is soooo dim and i can hardly see what i am doing! please can u give me a solution to solve this problem??
The easiest way to increase the brightness is to hold down the (Fn) key, on the bottom left of the keyboard next to the ctrl key. While holding down (Fn) tap the right arrow key to increase the brightness. The left arrow key can be used to decrease the brightness. If this doesn't work, you may have a bad LCD screen.
Mar 27, 2011 | Computers & Internet
How do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
I have an ACER X203H and cannot adjust the contrast or the brightness. I can bring up the MENU, however I cannot adjust because when I HIT ENTER the menu disappears.
Press the Menu key on the Monitor to bring up the dialog box press Menu again because it defaults to the Brightness Icon. You will see the lower half of the dialog box change color. Use the left or right arrow to move off of Acer eColor Management to the User setting. Then press Menu again to edit contrast or brightness. User the left and right arrows on the Monitor to move to the desired adjustment, press Menu to allow adjust then arrow left for less or arrow right for more.
You really just keep moving between the Menu and arrow til you get it right.. I definitely needed to turn down the brightness on my monitor.
May 04, 2010 | Acer X203H bd Monitor
My acer netbook screen is always dim even when it is plugged into the wall
adjust brightness settings on most acer laptops u hold the FN key and press one of ur arrow keys quite often the left and right for brightness up and down hope this helps
Mar 11, 2010 | Toshiba Satellite 5205-S503 Notebook
How do i adjust the screen brightness on the travelmate 4150
hold down Fn(function) key on the left side of the keyboard. Then hold the right arrow key for more brightness or left arrow key for less brightness.
Oct 26, 2009 | Acer TravelMate 4150LCi Notebook
Brightness menu keeps popping up
This problem is usually caused due to a faulty microswitch in the brightness button. To rectify this, you'll have to change this switch.
Get your monitor serviced by a qualified service personnel.
Hope this solves your problem. For more help or clarifications, please reply. Thanks.
Aug 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
Screen not bright enough
hit and hold the fn button and adjust the brightness with the right arrow. krakkerjack
Mar 16, 2008 | Acer Aspire 5315 Notebook
Moniter brightness
Have you tried using the manual controls on the keyboard for changing the brightness (Fn right arrow)?
I think the epower management is crap, usually I just uninstall them all and adjust things manually.
Jan 12, 2008 | Acer Aspire 5100 Notebook
HP Pavilion a305w (DM181AR) PC Desktop Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
