Question about Samsung HLP5067W Television
Hlp5067w won't come on & I've replaced the bulb.
With the back panel open, I can see the new lamp trying to start up and it even makes a loud buzzing sound, but it will never actually turn on.
  • dannb65 Nov 18, 2008
    We recently went through the same thing. The loud buzzing sound was the color wheel which also had to be replaced.
  • 3 Answers
If you hear a clicking sound in your bulb area like an arcing sound it's probably your ballast trying to fire up your bulb. new ballast easy to replace and around $100.
Posted on Apr 15, 2009
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
Bulb has gone out and now makes a loud noise
The noise depending on where it came from may be normal. You wont be sure unless a TV repairman checks the boards to know for sure, or you could replace the bulb and hope for the best.
Jul 19, 2010 | Panasonic PT-56DLX75 56" HDTV
Our Samsung HL-P4663w television bulb, BP96-00608A(P), cracked and we just replaced it with a new bulb. When we turned on the TV all we got was a loud buzzing sound and no light on the screen. It is now...
You probably don't have the new bulb seated properly. Does the buzz last for about 5 seconds, quit for a little bit, and then repeat? If so, then it is the ballast trying to start the lamp but for some reason or another, the lamp is having a problem.
Aug 01, 2009 | Samsung Televison & Video
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
My samsung hl-p5067w does not work
I would see if it's the lamp ballast only about $100.00 and easy to replace, it's the part underneath the lamp that fires up the bulb. The light engine itself is over $900 to buy and not worth it! I have same T.V.
Jan 31, 2009 | Samsung HLP5067W Television
HLP5067W Going on and off
Sounds like the bulb needs to be replaced. With the tv you have the Bulb last about 6000-8000 hours. If you think that is about right then you it most likely is time ro replace. You should be able to find the replacement bulb from the manufacture and then find it online to purchase.
Sep 20, 2008 | Samsung HLP5067W Television
I have a Samsung HL-P4663W TV. Last evening we heard a pop and then the screen started to shrink in size and a loud buzzing noise could be heard. The indicator lights on the front panel indicate that the...
After much research, it became apparent that the most logical culprit after the lamp was the color wheel. It has been replaced and the set is working again.
Aug 21, 2008 | Televison & Video
Buzzing and glowing on circuit board
That white cylinder is a capacitor and is very dangerous, you need to discharge it and replace it. Does the top seem to be bulging on it? If so, it is bad for sure and it is cheap for a new one. If it continues to buzz after replacing it, then your board has a problem. Replace capacitor before replacing lamp. The lamp still may be good
Jun 06, 2008 | Hitachi 42V715 Rear Projection Television
Samsung HLP5067W Television Logo
158 people viewed this question
Henry  Thomas
Henry Thomas
