Question about Hunter Heating & Cooling
I can't program my thermostat
I can't figure out how to program me thermostat. i tried and thought i did by followwing the instructions on the therostat but every time the heater is on it kicks to 60 degrees at some point during the night. how do i change that? we bought the house with it already installed and i don't have a manual.
  • 85 Answers
Use the mode button till program shows up then adjust temp with arrows and hit set
Posted on Nov 14, 2008
Not Warming Up
I'd have to suspect something wrong with the thermostat. It may be opening too fast, or it may be opening too much. Try a Ford thermostat to be sure. The amount of the opening of the thermostat will control flow characteristics, so maybe yours is opening too much. Just a thought.
Nov 15, 2013 | 1992 Ford Ranger
Home heating
Try pressing the RUN PROGRAM button this should return things to normal operation.
May 23, 2013 | Honeywell Heating & Cooling
Memorex mp4047 Personal CD Instructions needed
You may download a copy of the user's guide here.
Dec 19, 2012 | Audio Players & Recorders
New battries in Duracraft Programmable Thermostat for A/C...still won
Remove the thermostat and just touch the wires together and make it run until heat wave is over then figure it out. Kinda of a pain but at least it be cool
Aug 07, 2017 | Honeywell Electronic Programmable...
I'm trying to figure out how to change the
Hello victoriaulre,
Below I will provide step by step instructions and diagrams.
1. Drain radiator.
2. Remove the air cleaner duct for access radiator hose.
3. Reposition the hose clamp( circled in red) and then remove the radiator hose from the thermostat housing.See image below.
4. Remove thermostat housing bolt/stud.
5. Remove the thermostat housing and gasket.
6. Remove he thermostat.
7. Clean the gasket surface on the thermostat housing and the engine block.
To install, reverse above procedure.
Torque the thermostat housing bolt/stud to 18 ft.lbs.
Fill radiator and check for leaks.
I hope this helps.
Regards,
Jerry
Sep 12, 2011 | 2006 Pontiac G6
I am trying to program or override settings set by our gas supplier for our remote for model 3002. I want to be able to turn it on and off manually and it not work by thermostat mode. Can't seem to...
Love the SkyTech Remote Controls. Been selling them for years.
To override the thermostat feature and go back to manual operation, press the MODE button twice. That will turn the burner OFF. To turn the burner ON in manual mode. just press the mode button once. Everything will remain in Manual Mode, until you change it back to Thermostat or Time mode.
The link below is to your Owners Manual, which you can download and print.
http://www.skytechsystem.com/editor/assets/installation%20files/3002%20Instructions%20SSI.pdf
Hope this helped you. Please be kind enough to let me know.
Rich
Mar 06, 2011 | Skytech 3002 Fireplace Remote Control with...
My program sequence has been fine. Last week the time was blinking and then blanked out so I thought it was batteries. Changed them, now the time is wrong, it's still blinking but I can't change to the...
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 21, 2010 | Honeywell Programmable Thermostat Heater
Model ct3600 thermostat not working
I know it sounds simple but the batteries are probably in the wrong direction. If they are correctly installed and fresh you will usually get a display.
Nov 01, 2008 | Honeywell Programmable Thermostat Heater
Where is the thermostat on a 1996 Avalon?
follow the upper radiator hose away from the radiator toward the motor and that is where you will usually find the thermostat housing.
Sep 23, 2008 | 1996 Toyota Avalon
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
181 people viewed this question
Top Hunter Heating & Cooling Experts
1STHVACMAN
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
