Question about Gateway (802.11usb) Wireless Adapter
I cant connect just one network
My adapter i think its work proprety , but resntly i cant conect to just one wireless network , in spite of that once i had work with it, it is just this network and the all other its work fine, and i want to not that this network working well just with my labtop its dont work?
its will be fine if the problem can solve.
thank
Diab
    Genius:
  • 1,124 Answers
Be sure that your wireless network is working
Check your wireless router settings
Check if you see any other wireless network available on your computer
Test connection, see if you pulled an IP address
Go to the Windows desktop
Select Start then Run
In the text box type: cmd (WIN98/SE type command)
At the command prompt type: ipconfig
4. What does it read as the IP address?
* If it reads 192.168. something dot something then you are pulling
an IP address and are connected to the network. The problem is
software related, check your firewall, and wireless card configuration.
Also check any WPA or WEP encryption keys. Check with the respective
manufactures.
* If it reads 0.0.0.0 for the IP address you are not connected to the network.
* Check your connection configuration and the adaptor.
* Check with the respective manufactures.
STEP TWO/ Basic troubleshooting continued....Testing the adaptor
1. Go to Windows desktop
2. Select Start then Run
3. In the text box type: cmd (WIN98/SE type command)
A DOS window will open.
4. At the prompt type: ping 127.0.0.1 (reserved IP address for all adaptors)
5. Check the line that reads "packets sent = 4, Received = 4, Lost = 0
A. Zero is good, the adaptor is working. Again check the connection
configuration,and the adaptor configuration.
It may be a power issue especially with older or less expensive computers
or wireless cards.
* Check the antenna location, are you inside or outside, look for interference.
B. If it reads all 4 packets lost, the adaptor is not functioning.
* Check and update the drivers, Contact the respective manufactures.
* If it shows any number of packets lost (you are dropping packets)
it is an adaptor or signal strength issue (generally form the laptop side,
not being able to reach back) especially with older or less expensive
computers or wireless cards.
* Update the drivers
* Check antenna location, or distance from the signal
* Contact the respective manufactures.
Posted on Nov 14, 2008
I want to be able to log on to unsuported networks and free wifi hotspots and I was able to until about a week ago. tried to log on at my local court house where they offer it free with out a password but there is a red x next to the publicnet network now. I have check the IP info using the steps. It shows the adaptor is working I don't seem to have a power issue.
Posted on Jun 30, 2009
I have a samsung LCD TV Model LA40C650L1R newly purchased a week ago . it went with an offer of free wifi wireless LAN adapter.I cant seem to connect it in the internet. I did all the configurations the...
Please test the WiFi with a laptop or netbook, if Internet works with it, maybe you have bad settings into the wireless adapter, you could use the PC wireless connection parameters (SSID, IP address, subnet mask, gateway, DNS) as reference with the data obtained with the TV wireless adapter, the only difference must be the IP address, the rest must be the same since they're using the same network.
Mar 15, 2011 | Samsung Televison & Video
We've tried the belkin play wireless usb adapter in 2 laptops with xp pro and it wont connect the signals great it says the card is working properly but it just says it cant connect i've had this same...
Have you got two wireless icons down on the right by the clock. As it may be using the belkin wireless manager to control the device rather than the windows version.
Mar 11, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
Card doesn't connect to router.
This could be cause by many things. Check your router and see if there are any wireless security or locked mac addresses (locked networks).You can always reset the settings it by pushing and holding the reset button at the back of the router. Also, is the card able "see" the router? If it cant "see" the router, you are probably not in range that the router, once again, has a locked network.
Mar 07, 2010 | Linksys 2.4 GHz 802.11b Wireless - B...
Need to conect with wireless card to internet. moved and am trying to connect to my neighbors wireless modem with his permmision of course. windows message is that it cannot configure wireless connection....
Once you detect his network he wil need to give you his encryption key in order to connect. Otherwise you will be denied.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Connected to wireless network, but cant browse internet.
I think there might be lost in the packet sending.
You said the PC is still connected to the network but not able to go online.
Is there any other wireless computer which is able to go online wirelessly and working fine.
If yes then try to uninstall and reinstall the adapter.
If not then check the router wireless settings.
Click Here for more info about networking.
Oct 08, 2009 | Computers & Internet
Computer not conecting to internet
If you have not installed the USB adapter driver and configured the wireless network , you need to do that to connect to the internet. Once you have cd and installed the driver , you need to enter Wireless access key or SID to set the adapter to connect .
Sep 18, 2009 | Acer Aspire™ T180 PC Desktop
Cant conect to internet using wirles with Windows Vista
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck.
Aug 30, 2009 | Microsoft Windows Vista Home Premium with...
I have a xbox 360 wireless network adapter and every time i try to connect to a new internet conection it wont let me connect and when i do get it to connect im able to play for 5 min and then i get...
When you try to connect to a different wireless network, you should go into system settings, network settings, and then configure network. Once you see the basic setting, press the A button to setup the new connection. This should allow you to connect.
It is possible that you have a faulty wireless adapter. You could test your wireless adapter on a friend's xbox to see if the problem follows the adapter.
As far as your downloaded videos are concerned, if you reformat your hard drive, then yes all of your downloaded content will be gone.
After the reformat, you should be able to download the content you've already purchased, "as long as you're downloading it to the same console you were using when you first made the purchase."
If I were you, I would verify this with Microsoft before doing the reformat.
Jul 17, 2009 | Microsoft Wireless Network Adapter Xbox...
I just bought a wireless xbox 360 adapter, but there seems to be one problem. My xbox cant find any networks. I've been thinking its because my internet is apart from the main building of my home and is in...
The newer 2.4Ghz or 5Ghz wireless routers should reach a couple of hundred feet. Make sure you do not have your SSID hidden. If you do, you will need to manually enter it into the xbox settings along with other security you have on the router.
Jul 08, 2009 | Microsoft Wireless Network Adapter Xbox...
Its just not working
dissable your wired network card in network connections and then the ip address will be allocated to your wireless instaed, click refresh a few times in internet explorer.
Sep 10, 2008 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Gateway (802.11usb) Wireless Adapter Logo
217 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
