Question about Panasonic PT-51HX41 51" Rear Projection Television
Panasonic pt-51hx41 i recently had the color chips replaced but now after 3 months on the left side of the screen i have a green line. from top to bottom going across the screen about 3 inches of the screen at that side everything is outta wack i tried to fix it using the remote but the green line seems like it is at the end but i can move it to the right of the screen no problem but wont go left any further, when the repair guy was over he had a hidden screen pop up with about 100 little boxes is that the way i can fix it or is the color chip shot again, also if possible can i use the hidden screen, and how do i get to it the repair guy would not tell me or show me that
  • 65 Answers
I usually tell people at the outset that if they get into their service convergence menu and mess it up i wont be able to figure out what they did and you dont wanna do a scratch convergence to this chassis install new stk packs and the associated supply resistors cant miss em three 10 ohm 1/8 watt in parallel justt had one that i had replaced only of the two packs with a higher current stk pack ie; stk 392 -120 150 etc the resistors were subbed with a single flameproof 2.2 ohm 1/2 watt the service menu on that product is an art not easily mastered and am assuming that your skill set is not capable of even attempting any of this pay someone about 400 bucks for inhome call or go down to wally world and shop for a new crt projo tv i think the economics of it will quickly become apparent
Posted on Dec 09, 2006
    Sergeant:
  • 308 Answers
I suspect that you have several capacitors in the convergence circuit that have gone out of tolerance if this problem did not show up until several months after the repairman left. These parts usually have to be unsoldered, tested for capacitance and equivalent series resistance (ESR's) and replaced one at a time. It is very unlikely you'll be able to adjust it out. If the set is over 7 years old, I would consider replacing it with a HDTV set. Otherwise, it could run about $400 to repair I would guess.
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Green color projection is lifting from the bottom left corner of the screen. Convergence adjustment for the green projection is unresponsive
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number (STK392-110. When Convergence Output failure is
detected, it’s recommended that both IC’s be changed.
Thanks for choosing FixYA, Big Irish.
Dec 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Convergence on lower half of the screen is off, green arc appears
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 05, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
Jan 21, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Green convergence on Panasonic PT-53WX42 is not ligning up...
Does not sound like the chips are bad.
What you need to adjust is "SKEW". You need to enter "service Mode" then go into "Coarse Convergence". Skew can be adjusted for all 3 colors. Unless you have the service manual, these corrections should not be attempted.
To clean the INSIDE of the screen, you really have to disassemble the TV. Remove all the screws that hold the "back" ( the piece with the mirror) to the front (screen) assembly.
The screen can be cleaned with a solution of diluted isopropyl alcohol, no more than a 50% solution. Drugstores will carry it, but it might be 70%-90%. Just dilute with distilled water (not tap water as it contains minerals). Personally I have used 70% with no ill side effects but 50% is recommended.
Dec 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
PT-53WX52
  • Screen looks 3D
Dec 02, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Green and red color problem on bottom left to a little past the middle of the bottom of screen
the convergence ic's are breaking down and require replacement should cost under $ 250 depending on your service shop.
Nov 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Problem is double lettering PT-51HX41 51
What is the resistor location as shown on board.....for instance,
R856.......
Oct 29, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic 52"problem
You need to change the two convergence IC's - Generic part# STK392-110, Panasonic part# C5AA00000203. You might have problems using the generic #, I would use the Panasonic #
Sep 26, 2007 | Toshiba 46HM95 46" HDTV
Panasonic PT-51HX41 51" Rear Projection Television Logo
238 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
