Question about Polaroid FLM-323B Television
Response to your advice flm323b no pwr. deanhixson@sbcglobal.net
Posted by deanhixson on Nov 13, 2008 Report abuse
lighting struck pwr lines. fuze blown. fuze now blow upon pluging into wall without pushing the pwr on button.
ohm reading .... would not the ohm reading across the pwr inputs illiminate the xformer and an ohm reading across the large cap also rule out the bridge ckts?
  • 1 more comment
  • deanhixson Nov 14, 2008
    thanks, i will follow your advice. I have dated experience. 30 yrs ago i was in computer maintenance
    dean
  • Anonymous Nov 23, 2008
    no sound
    no sound and speaker good
    President:
  • 624 Answers
No, it will not. You must understand what type of readings you are supposed to get from them before you can determain if the reading is correct. A transformer will measure nearly zero ohms when measured across the primary or when measured across the secondary. You must know what the leads of the transformer are. Troubleshooting a power supply can be difficult at times. If I had the schematic for this unit I could probably point you in the right direction pretty quickly, but I do not have one. Most times the power cord will go directly to the transformers primary, maybe thru a switch and a fuse. In your case I think that it just goes thru a fuse and then to the transformer. In this case, it is likely that the transformer primary is shorted. If you know where the secondary is at for the transformer, you can disconnect it and then put a fuse in and see if it still blows the fuse. If it does, and the power cord is connected directly to the transformer without any other circuit branched off of it, then it could only be the transformer. If the power cord feeds another circuit, like for a standy-by circuit which supplies a voltage for the micro so the TV can turn on, the problem could be in that stand-by circuit. The stand-by circuit is normally a smaller transformer with a couple of diodes used as rectifiers and a smaller capacitor or 2 that also lead you to a voltage regulator or transistor that is used as a voltage regulator.
The most important thing you need to do is isolate the main transformer if it goes directly to the power cord. By disconnecting the secondary leads of the transformer you take it out of the circuit so that nothing on that side of it can be causing a short. If the secondary of the transformer is soldered directly into the circuit board, then you need to take that solder off of the secondary so that it is no longer in the circuit. You will need to do that with some solder wick which is used for removing solder. The leads for it must not be touching any of the circuit traces on the board. It is the only way to be certain that the secondary is not causing the short, or at least nothing in the circuit past the secondary is causing the problem.
This really should be an easy problem to find, you have a direct short somewhere, or at least a component directly in the path of the power cord that is near shorted and causing massive current draw. This is where the schematic is needed since I can not be there with you to actually look at it with my own eyes.
I hope this helps you find this problem, if not, we can continue this conversation. But I did notice that you have not rated, accepted, or not accepted any of the experts solutions. I believe in order for you to see more solutions you must rate the solution you have so far. If you accept a solution from an expert it will be that experts responsibility to help you solve your problem. Please be aware that some problems just can not be solved in an online forum, sometimes it it requires the technician to actually get their eyes on it. I would also like you to know that even if you accept this solution from me in this thread, I will not get the credit for it unless you accept the solution I provided for you in the paid question you posted earlier today. I can always post another comment on the paid questions thread if you would like to accept it there so I can get the credit for it. Any post you make on the paid thread you should use the experts name you want to communicate with so all the experts know who you are talking to, unless you are just wanting to let all the experts know .
One more thing you should know, since they do not explain it very good to the customers of FixYa!, the ratings in this thread are different from the ratings on the paid thread. Anything less than a FixYa! rating on this thread will lower my overall rating, but any ratings on the paid thread have no effect on the experts ratings. So a "Thanks for Trying" rating on the paid thread is not a negative rating, just means you want more help from other experts. But a "Thanks for Trying" on this thread is a really bad rating that no expert here wants to get. In the paid thread, the experts are just working to make money, here it is free and effects our overall ratings.
I hope this was not confusing for you, I can try to explain any of this post you do not understand, just let me know what you need explained.
Dave
Posted on Nov 14, 2008
  • Dave DeGain
    Dave DeGain Nov 14, 2008
    One more thing you need to know. Never, ever, ever, solder or do anything else while the power cord is still plugged into the wall. These units have high voltages that can kill a person if they get shocked.
    Please be careful, I would hate to see you get hurt trying to fix this TV.
  • Dave DeGain
    Would you mind going to the post that you made and paid for, and accepting my solution so I can get the credit for helping you with this problem. I will go and make another post there shortly, so if you get it in your email you could accept it there. I would really appreciate that, and it would keep one of the other experts from getting that credit for doing little to nothing. If you never accept any solution from that post the credit will go to the person who first posted a solution after it has been 7 days with no solutions being accepted.
    I am more than happy to continue giving you help with this problem, but it would not be fair for me to spend all this time helping you and then somebody else getting the credit for it when they did not do anything else to help you.
    One more thing about your TV. After you find the shorted component that is causing the fuse to keep blowing, it is possible, and even likely, that you may have more components that are bad. It may require that a service manual be purchased to continue troubleshooting the problem. Even the best technicians need the schematic in most cases. It is vital to be able to see the circuit design. It would also be required to be able to get the proper parts that may need to be replaced. Similar parts can not be used, it must be the right specifications to ensure proper and safe operation of the set.
    I am glad to hear you have some repair experience, I can now assume that you are aware of the hazards when working with electronics. But just so you know, TV sets have much higher voltages and currents than any computers.
    Dave
Cd plays but no display on screen and no touch response.
No display in monitor [Solved] - CCM
ccm.net > Forum > Hardware
Jan 11, 2013 - ... the systeme "always take the main cord off the case before touchinganything ... now unplugged your dvd/cd rom and start your system.if you see no change .... display stayed black even though I could hear the login screen tune play. ... for aresponse but it looks to me as if I shall have to get a new screen. Monitor Gets No Signal / Computer Won't Boot
Nov 12, 2012
Ps3 will not load.
Nov 10, 2012
More results from ccm.net
Double din touch screen not working - YouTube
? 1:51
https://www.youtube.com/watch?v=7pRcIxhbYq4
Oct 3, 2009 - Uploaded by Eighty7Olds442
My screen is not turning on it stays off but if I tuch it it works. Read more ... Only 2 icons of right side were ...
PC powers up but won't POST, no HDD activity light, no ...
www.tomshardware.com > Forum > Systems
Tom's Hardware Guide
Nov 21, 2013 - 24 posts - ‎15 authors
The fans spun and all, no beeps, but when I tried to turn it off with the power button, it worked. ... response from pressing power button (no POST) (Custom, self-built, ... shown on screen, monitor did not wake up, pc power led on yes, no ... nothing, did everything,remember i did not touch the pc when it was ...
Solving Problems
Dec 21, 2015 | Cell Phones
Someone other than myself is using my sbcglobal.net email address.How do I stop this unauthorized access.
Hi deenastrang
I'm not au fait with the sbcglobal.net E-mail interface, but the general principal for what you need to do is this:
If you still have access to the E-mail account, log in, go to options > accounts > password > change your password > apply > ok > back to mail.
Since, I believe, SBCGLOBAL is a financial services organization, this incident could have serious ramifications including potential fraud. So, I suggest, as a matter of urgency, that you report the matter to your superiors and your firm's head of IT, so the matter can be fully investigated.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 07, 2011 | Computers & Internet
I have two people on face book that are sending me personal abusive messages and the other is posting disgusting posts about me one is blocked and the other has never been added. This is supossed to be a...
I think you can literally call the non emergency police line in your town and report it. You should also make screen shots of this abuse.
With the abuse on the screen where you can see it press Ctrl Alt Print Screen and that makes a copy of the screen.
Then you have to paste it to Microsoft Word or Word Pad or Microsoft Paint. Save it and that is your evidence. You can send this to facebook admins as well. You should have all your friends report everything the users posted and the users themselves too so that hopefully they get permanently blocked from using facebook.
Jan 05, 2011 | Facebook Social Network
How to report abuse from another user on facebook
Facebook suggests the following:
How do I report abuse? The most efficient way to report abuse is to do it in the same place i... The most efficient way to report abuse is to do it in the same place it occurs on Facebook. For example, if you receive a harassing message in your Inbox, you can report the message by clicking on the "Report" link next to the sender's name. If you receive a harassing message from a person who is one of your Facebook friends, you should remove the person as a friend and report the message. Reporting a message as harassing will automatically add the sender to your Block List. You can also use the "Report/Block this Person" link that appears at the bottom of the abusive user's profile.
If you learn that someone is continuing to make abusive comments about you even after they've been blocked, a friend can report that person on your behalf. Reports are confidential and the user being reported does not know that they have been reported.
After a report is submitted, you will receive confirmation that the report has been received and we will investigate the issue to make a determination as to whether or not the content should remain on the site based on our Statement of Rights and Responsibilities. A Facebook administrator looks into each report thoroughly in order to decide the appropriate course of action. Go to the following link: http://www.facebook.com/help/?faq=13247
Apr 05, 2010 | Facebook Social Network
Ignition switch won't turn off motor
pull the steering wheel and replace the key switch assembly. Dealer part.
Nov 25, 2008 | 1993 Lincoln Continental
Follw-up
check the mass air flow sensor if still no spark check the coil packs for power if they dont have power check all fuses and relays if they are all fine look for a short
Nov 17, 2008 | 1996 Pontiac Grand Am
Re: Creeping black line
Hi mrtaz187 -
Well, the pixels can go bad on the LCD monitors and from what you are explaining, it certainly sounds like this is the case on your monitor. I wish that I had better news for you but the monitor will have to be replaced. Sorry. I know that Walmart has had these monitors on sale in the past and they have offered a 13 month warranty. If you could return it from where you bought it (under warranty), that would be the best solution... otherwise it will need to be replaced because usually the bad pixel problem grows worse over time.
Hope that helps,
Take care,
Michael
Nov 12, 2008 | Computers & Internet
I can't open yahoo mail on my pc
it says my account is locked
Nov 10, 2008 | Yahoo Mail
Have you heard anything about this?
Hi, try the monitor on another PC , if you got a laptop you try it , to see if it is the monitor . The problem could the video card on your PC., let me know if the light is yellow or green.
Nov 21, 2007 | Dell E173FP 17" LCD Monitor
Plastic arm of water dispenser broken off - need help trying to remove plate to access screws for replacement
Try looking under bottom edge of control pad that says monogram on it. You should see 2 or 3 holes. Push in with a blunt object in either end hole while pulling panel forward. Then dot the center if has one, then the end one. MAKE SURE YOU HAVE POWER OFF!! Now you can see 4 screws to access rest of dispenser.
Nov 19, 2007 | GE GSS20IEP Side by Side Refrigerator
Polaroid FLM-323B Television Logo
161 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
