Question about Panasonic D-Snap SV-AV100 Digital Camera
Problem with dark lcd but plays back does not record
I have only used my camera a few times and one day it worked fine and the next all i got was a dark screen.i noticed a small indentation on the outside of the camera on the lcd side i am hoping no one damaged it. it does not take images just a black screen. i tried to reset the camera but it still does not work. i have taken out the battery still no luck. i am going on vacation in two weeks and would love to take my camera along. can anyone help me...
    Novelist:
  • 153 Answers
Hi a bit late I know but it may help someone. If you can see the menu clearly on the screen but all the camera will shoot is a black image, the problem is a stuck Iris... see my article http://zyvid.com/smf/index.php?topic=449.0
cheers
Posted on May 24, 2008
Take a movie, then try to download it. If you captured video, then camera works, but your screen is damage and may need replacing.
Posted on Nov 11, 2007
Dark Screen on Acer Aspire 5735z
That sounds like the bulb in the screen is blown. I have changed them at times but it is very tricky and I'm pretty sure you won't find a reputable place to do it for you.
Effectively in answer to your question the only rational solution is to change the LCD panel, it's not very difficult to do on the aspires, just a few screws and peel off the tape holding the screen connector in place, disconnect the inverter cables, (pink and white) and swop for the new panel. check ebay etc for a new LCD panel they're not that expensive. Try to get a new one instead of a second hand one. to find out what panel you need, you'll have to open the screen and look at the back, it'll have a paper sticker showing the model number.
Jun 12, 2013 | Computers & Internet
When i put on the camera the monitor is so dark i can not see what i am taking out
Please clarify a few things so someone can help you.
1. Are you saying it's too dark when playing back previously taken photos, when recording new photo's, or just all the time.
2. Can you see the camera menu's ok but not the live view of the subject.. or is everything just too dark?
3. Does the Status Indicator LED on the back light up showing that the camera has adequate battery power?
Here are some suggestions (You can quit when you find one that works).
1. Check that the monitor brightness setting is set to medium at least in the menu's. Go to SETUP MENU and then MONITOR to check this. It has 7 brightness levels.
2. Press the display button on the back a few times while the camera is on. This toggles the display setting between various settings such as Off/ On / Info. The display may simply be turned off since that is an option.
3.. Try a 2nd set of new batteries.
4.. If you can read the menu's then select the option to reset the camera to factory defaults. Do NOT select to format or erase your memory card, that is not required and it's not the same thing as a reset. This just sets the main functions back to their original settings.
5. If it works fine for playback but not for recording then check that the main record settings are correct for the type of scene. For example don't use Beach, Snow or Candle mode for regular daylight shots.
6. If the built-in screen has an issue the video output jack should still work since that is a different circuit, So connect the camera to a TV and see if it works then. That also lets you see the menu's to check the settings if the built-in screen has an issue.
7. Check that "AUTO LCD OFF" is not set.
8. If none of these suggestions resolve it then ask a local photographer to take a look at it since there may be more solutions that become evident when you see it in person.
Lastly ...
It could have a bad CCD sensor or corrupt firmware but I can't say for sure since there was so little information provided.
The factory can fix any problem or replace the camera and internal programming issues can often be fixed with a firmware upgrade. But don't do that unless you are familiar with it.
Jul 25, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Sony TRV308 Camcorder is not picking up light when recording
Hi there and welcome to FixYa.
Do your videos come out dark when you play them back? Or Is it dark while you are recording?
If it's dark while you are recording, is it dark in the viewfinder, or the LCD screen?
If your videos come out dark when you play them back, check the manual exposure. Hit the exposure button and turn the sel/push execute wheel to change the exposure to lighter.
If you are looking through the view finder to record and it's dark, check to make sure the window is clean.
If your LCD screen looks dark while your recording, put the power switch to player, hit the menu button and scroll down to LCD, select it and turn the select wheel to brighter.
I had to guess at what your problem was due to the information you provided, so I tried to cover the most obvious. If I failed to answer your question, please comment and be more specific.
Hope this helps, and thank you for coming to FixYa.
Rob
Mar 20, 2009 | Sony Video Cameras
Sony Handycam TRV/118 NTSC
Your camera seems problem of bad CCD Imager. Check details on following Sony Official website or give me correct model number of camera.
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Have
Aug 01, 2008 | Sony Handycam DCR-TRV265E Digital...
JVC GR D74
Firstly check if a/v mode is on ..in or..out.If it is on out then your ccd image sensor is faulty.
Mar 18, 2008 | JVC GR-D20EK Camcorder
Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
Feb 02, 2008 | JVC GR-D33US Mini DV Digital Camcorder
NIGHT SHOT USED W/ TOO MUCH LIGHT MAY HAVE WRECKED IT.
"Nightshot" mode removes infrared filter from light path, fixes exposure to 1/60th second and sets iris to maximum.
Probably bad CCD, possibly could salvage from another camera.
Cameras are easy to take apart, but ribbon cables are VERY delicate and difficult to remove from connectors on main board.
My suggestion is to buy another camcorder, which uses the same tape and to use the old one to rewind tapes and for video transfers.
Dec 21, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Playback difficulties
Not specific enough but I would run a head cleaner thru it for 10 seconds and see if that improves things and always use the same brand of tape to prevent gum issues.
Jun 01, 2007 | Canon ZR60 Mini DV Digital Camcorder
Need some help with DSC-W1
memory stick pro comes in 4gb, 2gb, 1gb, 512mb, and 256mb sizes. sizes up to 1gb (i.e. 256mb, 512mb, and 1gb) are what the book is referring to.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Panasonic D-Snap SV-AV100 Digital Camera Logo
82 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
