Question about SanDisk Sansa e250 MP3 Player
My sansa fell down and now its saying refreshdata an blinking on and off how to fix it
  • seleam Nov 16, 2008
    exacly the same seleam@hotmail.com
  • su_manda Dec 17, 2008
    my computer does not recongise my sandisk sansa e250 player what should i do
  • 8,596 Answers
Reformat the player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
  • Corey Knoettgen
    Corey Knoettgen Dec 18, 2008
    disconnect the player from the computer, turn it off, hold in the REC button, and reconnect the player to the computer while holding the REC button in. Keep holding the REC button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
What does 6 red blinking lights mean on sony projection tv
the lamp burnt out and need to be replaced my just like burnt out while i was playing zombies on call of duty and i can fell my controller vibrating so i got some downs, but um ya people say there's a door u can open, and u can basically open it and replay it, but people say i have to be careful of the glass i think its really fragile and you cant touch the glass when its hot, alot of people may not keep their manual for their T.V. so it may be hard to do it with out it. but yea ima try to fix mine and c what i can do well i hoe this helps u be careful fixing yo tv.
Jan 16, 2012 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Just says connected until the battery dies.
first off if you can turn the player off
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
if you can actually connect your sansa to the comp. and see it in explorer try this....
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
It keeps saying that its refresing database and is not loading
first try this...
Mar 13, 2009 | SanDisk Sansa e250 MP3 Player
I open my sansa view and the strip fell out
it can be fixed yes, but please use a reputable Kenwood dealer to carry out your repair
Dec 17, 2008 | Kenwood DNX7100 Car Video Player
No display
Probably hardware damage, but you can try the following "soft" fixes:
-Tha Mp3 Doctor
Jun 16, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260 cracked screen
dude i hate to say this but i really hope that you have the extended warranty on that player becuase your not going to be able to fix it sorry. i wish there was another way but there isn't
Apr 23, 2008 | SanDisk Sansa e260 MP3 Player
Break down
Reset the player, then run the Sansa Recovery Tool on the Sansa website. I had a Sansa Clip that was giving me all kinds of hell. It even gave me the MTP device pop-up indefinitely. I simply restarted my computer after restarting the player, and then recovering the player, and the player works fine again.
-Tha Mp3 Doctor
Feb 21, 2008 | SanDisk Sansa c200 MP3 Player
How do i fix my sansa
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Jan 05, 2008 | SanDisk Sansa e260 MP3 Player
Wont turn on
Probably needs replacing, but you can try these common software fixes
-Tha Mp3 Doctor
Jun 05, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
