Question about Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 printer / scanner
It wont feed the paper correctly.. It pulls it only on the right side and crinkles up in the machine...
    Novelist:
    Scholar:
  • 125 Answers
I don't have a 1240 printer but we have had this problem. Usually we just align the paper and there is usually a movable piece that keeps the printer snug and aligned. Usually we move it right at the edge of the paper. This usually prevents the paper from crinkling. If this doesn't work I would guess that one of the rollers is not working. But my guess is more of the paper guide that you need to move so that the paper stays aligned when it goes in. Let me know if this helps.
Posted on Nov 14, 2008
Lexmark x1240 printer jam pulls to the right
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
  6. If cartridge area is clear, close the cover.
  7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark X1240 All-In-One InkJet Printer
Paper misfeeds, more on one side then the other
hi
this mostly occurs due to either major dust accumilaton or paper peices being stuck to the paper feed rolls
try and clean the rolls with some spirit and this should start working fine again
hope this helped
cheers
Jun 23, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 All-In-One Printer Control Panel
Hi
This is the description of printer control panel
green button-START COLoUR COPY BUTTON.....place a documnet on scanner glass...press this button..u would get colur copies of the document
Black button-START BLACK COPY BUTTON.....place a documnet on scanner glass...press this button..u would get black copies of the document
white button on the left hand side-paper feed button..to load paper into the paper feed tray
white button the right...not sure:)....i guess it should be the scan button....
all the best
Apr 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
When trying to print paper pulls to the right and jams
try feeding the paper first, mine pulls to the right also, but if I hold it when is jerks, sometimes it will not jam
Dec 02, 2008 | Lexmark X1240 All-In-One InkJet Printer
Clearing a paper jam
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jun 15, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark x1240 printer will not print.
Keep your paper feed under 15 pages. The paper will tend to pull to the right, but it will print correctly on the printed page. 20 to 25 pages in the feeder will result in a paper jam. To find the status on the print job, go to your control conter and hit printers. Choose your spicific printer and you may beable to save the printjob.
Apr 16, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 Printer
Please adjust the paper guides and check the paper rollers for any abstructions...
All the best.
Regards
Mohammed
Nov 02, 2007 | Lexmark X1240 All-In-One InkJet Printer
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Lexmark X1240 All-In-One InkJet Printer Logo
162 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
