Question about Maytag Performa PAV3200
Magtag Performa washing machine
My washer will only spin on the presoak cylce .. it will not spin during any wash cycle .. the machine runs through the cycle (the dial rotates) but the tub will not .. anyone have any ideas ?? anyway I can fix this myself .. easily ???
  • 1 more comment
  • Anonymous Jun 10, 2008
    I have a maytag model no MAV4755AWW
    Bought the first of 2007. Out of warrenty
    It will not spin on spin cycle it continues to agitate.
    Called a repair person he said it would cost more than a new washer, but the repair person didn't act like he knew what he was talking about.
  • Anonymous Oct 11, 2008
    I have the same problem.
    My washer( maytag performa) is only 1.5-2 years old.
    I noticed the clothes were not as dry as they should be one day, and the next day they were wetter so I investigated and found that the tub was not spinning.
    My agitator agitates but does not spin.
  • jpaulxiong Dec 27, 2008
    I have a problem with my washer.the water is not come out.please help me out.
    e-mail jpaulxiong@hotmai9l.com
We have owned a MAV4755AWW washer for about 2.5 years. A local appliance company that has been around for a long time gave this model to us as a replacement for the last Maytag washer we bought from them that only lasted about 1 year before having serious problems. Anyway, our washer agitates but the drum won't spin. I spent several hours on Sunday. Removed the drum to verify that there wasn't any obstructions between it and the plastic tub. Replaced drive belt as it was slightly worn. However, I noticed the motor pulley was loose. I applied tention to the motor and belt and tried to tighten the locking nuts. They tighten but would not hold the motor in place (hold belt in position with the proper tension). Took the front cover off and I'm convinced the spin problem is the enclosed brake assembly located under the drum. The repair person above most likely was correct and was honest - it would cost too much with parts and labor to fix it. The repairman had to replace the brakes or brake assembly on the last Maytag we had for 1 year and he was at our house for awhile doing it. I have had it with Maytag washers. Our first one lasted over 10 years so I thought I could rely on buying Maytag again. They have lost my business. They are no longer quality washers. I will now buy another quality name brand. Also, I'm so mad about losing $500 that I will say the local store is in Marysville, CA. Only one well known store if you are from this area so buyer beware.
Posted on Aug 25, 2008
Washing machine water will not come out
Posted on May 13, 2008
  • 240 Answers
Sounds like you have a timer problem. Insided these timers are small switchs called contacts. These can sometimes get burnt, and wont function properly, especially if one cycle is constantly used for laundry (not your fault, just wear and tear is all). These are somewhat easy to fix, most just have one plug to plug and unplug, and removal of the rear of the dash is all. The timer knob cover just pops off (cap in the middle) then drop timer out. Problem is these timers are not to cheap in price. The timer number for this unit (I believe) is 21001701, and runs about $100. Please, check E-Bay for these parts, they usually are way cheaper and even though they may be used, they still carry the same warranty normally as the new ones, for half the price. Good luck, and let me know if you need further help.
Posted on Feb 03, 2008
Maytag performa washer only spins on 1 of 3 cycles.
This machines timer is bad ,basically you have bad contacts in the timer ,that why it only works at certain parts of cycle
Nov 20, 2013 | Maytag Washing Machines
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 12, 2011 | Washing Machines
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Maytag performa washer during spin cycle tub is making loud banging noise and continues even when clothes are evenly distributed
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Jan 03, 2010 | Maytag Washing Machines
IUs very loud during spin cycle and you would
It appears Maytag no longer produces the type of quality product we have purchased since 1970... we've owned three Maytag Washers - our last "performa" is a piece of ****!
Dec 23, 2009 | Maytag Performa PAV2200
Washing machine won't go into a spin cycle.
check the lid safety switch for proper operation
Oct 04, 2009 | Washing Machines
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Washing Machines Logo
1,189 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
