Need specifications on this furnace.
The furnace was installed in about 2000. It is a roof mount. We need the specifications necessary for a building permit.
  • 85 Answers
You need the model and serial # from the unit first
Posted on Nov 14, 2008
I am facing the RV Roof leaks and does not know the solution?
Hi, There is a product called "White Lightning" that is a paint on application for Aluminium roofs on RV's. There is also a product that is a rubber paint on application for RV's as well...don't know the name. If your roof is anything but rubber, I'd recommend a SOLVENT based product, much more durable in my opinion. I had a 34' motorhome with a leak along the canopy rail and I used a solvent based building caulking product used when putting down plywood flooring in homes to stop any squeaking, and it was great, acts as a glue as well. Can't recall the name, PCL Professional, something like that. You need a caulking gun to apply it, comes in a large tube. Hope this helps you stay dry !!! Cheers, Gary
Apr 07, 2014 | Blinglights Trailer RV Camper Mobile Home...
My high efficiency furnace has water (possibly condensation) running down the air intake pvc pipe into the furnace and all over the burner, gas valve, and wiring.
First, check the drainline from the furnace. You have a 90% gas fired furnace. Where 80% furnace has 1 heat exchanger, yours has 2 heat exchangers. And the second heat exchanger will cool the exhaust enough, that it ends up below the dew point, and your furnace outlet/exhaust will condensate. This drain is probably stopped up. Now, I've installed and service many of these systems and I've only seen the piping at the roof you described once. And that was when the roofers replaced the roof, damaged the furnace flue pipe, and tried to repair it themselves. Normally, and this may not apply to yours, we tie in the exhaust/supply lines about 2-3 ft. above the furnace. Then 1 pipe goes through the roof. Thus 1 pipe is a kit that has an inner liner & outer pipe(2 pipes in 1). Now I'm not sure if this is a problem or normal for your system, but it may be worth looking into. You should be able to find it in the installation manual, or call a local parts house that sells your brand, or as your tech. And if it's just your drain, forget all about the piping I mentioned. Hope this helps!
Mar 08, 2017 | Goodman Heating & Cooling
Sounds normal at first. Runs till first 1/2 segment of burner status lights come on then lights go off and unit runs for several minutes with all burner lights flashing and shuts off. Also has had an...
Sounds like a blockage in the exhaust line and a pressure safety switch is shutting it down. If its an 80% efficient furnace check the exhaust line and the roof vent cover for damage or blockage. If there's ice on the roof, take all necessary safety precautions!!!! If its a 90% efficient furnace, make sure that all the condensate lines are free of any blockage. Remove power to the furnace and remove and clean these lines. Also check the condensate drain lines to make sure that there is no blockage in the line. A water and clorox solution with help to remove any algea build-up.
Jan 27, 2011 | Heating & Cooling
I need step by step instructions on how to install an alternator belt into a 1997 kia sephia. Also need a list of necessary tools
Welcome to FIxYa.com
GENERATOR DRIVE BELT INSPECTION
1. Check the drive belt and pulley for wear, cracks, and fraying. Replace if necessary.
2. Measure the drive belt tension with a tension gauge.
Tension lb (N)
3. Measure the deflection by applying moderate pressure (221b,[9S N]) midway
between the pulleys. Adjust if necessary.
Deflection lb (N)
Adjustment
1. Loosen the generator mounting bolt and adjusting bolt.
2. Deflect the generator to achieve the specified deflection.
3. Tighten all bolts and recheck the tension.
Replacement
1. Remove the A'C and PS drive belt, if equipped.
2. Loosen the generator mounting bolt and adjusting bolt.
3. Remove the generator belt.
4. Install the new generator belt and adjust it to specification.
5. Tighten all bolts to the specified torque.
Tightening torque:
Mounting bolt:
2 7-38 ft-lb (37-52 Nm)
Adjusting bolt:
14-19 ft-lb (19-25 Nm)
6. Install the AC and PS drive belt: if equipped. and adjust to specification.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 17, 2010 | 1997 Kia Sephia
I have a 1998 Fleetwood mobile home with a Coleman electric furnace. I am doing a roof replacement. Is the ventilation motor/blower/control board on top of the roof necessary. If not, i want to remove the...
If the motor was there originally I would not remove it as it means something that can harm the occupants (gases, heat, etc) has to be expelled from the mobile home using that vent motor.
Jun 28, 2010 | Tools & Hardware - Others
Works good for about 3-4 minutes then starts cutting off and on frequently
You need more specific in ...is it a High Efficiency furnace????...Sounds like your Condensate drain is plugged...a Hi Eff furnace produces water that must drain away....when these hoses get dirty or plugged the water drains too slow and builds up causing the Pressure switch to open...momentarily or for a period of time...once sufficient drainage occurs the furnace will fire again...could also be a bad flame signal , Dirty Flamerod....which should be cleaned yearly anyway...emery cloth and the flamerod is usually about 3 inches long and mounted with 1 screw and usually a white or orange wire coming from it...it is the thickness of a coathanger and similar looking...simply shine it up with emery cloth and reinstall then observe again...if this doesnt work then it will likely be related to the Pressure switch...either as mentioned above regarding the condensate draining or could also be a defective Pressure switch
Oct 25, 2009 | Heating & Cooling
Roof Console on the espace
You can get to the aerial mount by removing the over head console. you need to unclip the front section (nearest the windscreen) then two screws and the console will drop down reveling the aerial mount.
Jan 17, 2009 | Car Audio & Video
Furnace gas pilot light keeps going out when windy outside
Honeywell makes an electronic ignition conversion kit. (White rodgers also has one but it uses a mercury switch which can be expense if it goes bad). A good service man can install the "Honeywell Y86 Universal Intermittent Pilot Retrofit Kit". This is a "complete" kit for converting a standing pilot system to electronic ignition. It includes a new gas valve, ignition cables with connectors. ignition module and a pilot assembly. It does not include pilot tubing (pilot tubing is cheap). This kit also comes equipped for either natural gas or propane. Your heating guys probably don't know about it because they are to young and not familiar with the old days. Or they just don't care and would rather sell you a furnace. I think that they just don't care. I live in Ohio I just opened up the "new" Johnstone Supply catalog. This part is "not" outdated its on page 450. Do not let these heating guys buffalo you into a new furnace. You are to smart for that! If you weren't you would have believed them and bought something you don't need. Instead of researching on the internet.
The bad news is this kit lists for $456. plus labor.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
