Question about HP Deskjet 2460 InkJet Printer
My printer hp deskjet d2460 is never stop blinking
Hi im romelie, my printer hp deskjet d2460 is never stop blinking and i cannot use it... i dont know whats the problem i have check the ink its ok... actually i have a refillable cartridge and i refill it just yesterday... Its started blinking last week... i need your suggestions please send it in my e-mail add... thanks ^_^
  • 1 more comment
  • Anonymous Feb 10, 2009
    my printer have the same problem.it wont stop blink.And it also had refill ink on it.but i have replace it with the original one, but it doesn't work. i have re install printer driver. but not solve the problem...
  • amarsanga28 Mar 09, 2009
  • bhanaidu Mar 27, 2009
    ple give this problem .my hp printer blinking the light
I have experienced the same problem. What i did was to find out what causes the problem. Since i have experienced that problem after changing my black cartridge (HP21), i have a hint that one of the cartridges is defective. Here's what i did which solved my problem:
>> I checked both catridges by removing it (one at a time - then closing the printer cover) and wait if the light will stop blinking.
>> If the light stops blinking, then the cartridge that you have removed is the defective one.
Hope this will solve your printer problem.
Posted on Nov 17, 2008
  • driverack Aug 04, 2010
    thank you Drix Maverick it help us a lot...=)
    Novelist:
    Scholar:
  • 125 Answers
I'm guessing here cuz I don't have a 2460. I have 4 other HPs though. I'm guessing that since you are using a refillable cartridge, you mayhave exceeded it's calculated service life. All the printer companies do this. If you are printing more than 500-1000 pages per month, your printer will just stop. I could be wrong but usually there should be an error message on the screen. If you need to empty the waste pad check out one of the experts here on Fixya I think it's worldvet for his solutions on waste pads. It is generic. The other thing is you may have to search for the reset codes of the 2460. Cleaning the waste pad will give you a temporary solution. The printer may ask you to have itself serviced. Let me know if this helps. If it doesn't let me know the error message or codes that you are getting. Sorry I can't help you as much.
Posted on Nov 14, 2008
  • 3 Answers
Go to the control panel printers and faxes screen and look in the right hand column for the "status" message. It should tell you what the problem is. Mine is currently telling me it's jammed but there is never any misfed paper, it just doesn't work right. The light then blinks and going to the control panel for printers and faxes you see "paper jam" instead of "ready". Fun...
Same problem here. No printing out of Windows, with printer reporting PaperJam (while there was none), Printing (while nothing happened), and the Power button kept blinking. Other important diagnostic is this:
Disconnect USB, keep power line connected though.
Power up D2460
Press the power button with the end of a pencil, while lifting the lid 4 times (it sounds silly, but use the pencil, otherwise lifting lid not possible). Lift lid as far as pencil will allow you.
This will trigger a self test print.
If selftest is OK, then problem probably is your drivers or other OS related issue.
However, in my case self test rpint did not go. Turned out it was a clogged up cartridge, that was an Office Depot copy (no HP original). As others found, if you remove one cartridge, and the other is fine, the self test print will commence and finish.
Posted on Jul 22, 2010
Question: My hp d2460 printer is telling me I have the wrong cartridge and I do not.
Answer:
I just solved it by pulling the cartridge out, printing a page with only the color cart, then replacing the black cartridge. it is working for now......
Posted on Oct 08, 2009
My " solution " was throwing the printer in the TRASH ! . I have never had any other printer where there wasn't manual buttons on the printer itself . Ever since I mistakingly bought the HP piece of **** I had nothing but problems . They make TONS OF MONIES SELLING INK ! , buy a competitors PRINTER ! , I DID !
Posted on Aug 17, 2010
I just disconnect my printer from ac and also usb,and then pull out both ink crtridges and then clean the space where cartridges touch the printer with rubbing alcohol and cotton swab and after wipe out it with paper tissue.it stopped the blinking.
Posted on Jun 30, 2010
I have the same blinking problem, and guess what i did, i remove the cartridge and put it back again..simple right?? how you put back the cartridge will decide the solution of your problem. Thanks, i hope this helps.. Note** When putting back the cartridge insert it not on the left side but on the middle.
Posted on Sep 23, 2010
4 Suggested Answers
Evilsmith
  • 26 Answers
SOURCE: hp deskjet 842c blinking ink cartridge light
You have to take off the clear strip of plastic over the copper area, or the printer will not detect it. There should be a green pull-tab on the cartridge.
Posted on May 07, 2008
  • 4 Answers
SOURCE: How to reset ink cartridges after refilling them
Go to the following website and download the freeware InkMonitor 2.1.2: http://www.pokluda.cz/. You have to add data about new cartridge. HP60 ink cartridge information, 200 pages per cartridge. This works great for me. It gives you a history of everything printed. This way you can gauge when its time to refill your cartridges. You must refill before they run out of ink or you will burn out the print heads and have to replace them.
Posted on Jun 06, 2010
SOURCE: How do i refill my HP M1005 MFP Laser Printer toner cartridge?
if any softwere is have you for chaquing my cartage how many days are left to changing thel me
Posted on Oct 28, 2010
Why there is continuous blinking of power switch and not giving self test hp d2460?
Please all connect cable and adapter disconnect and some time wait and proper connect all cables. Connection after if solved then ok other wise toner removed and reconnect, dust clean or reinstalled driver.
Read More support .... HP Printer Support
Thanks,
Jul 14, 2014 | HP Deskjet 2460 InkJet Printer
Hi im tina ive lost my cd for my hp deskjet d2460, i dont know which im gonna use the hp deskjet d2460 driver or the hp deskjet d2460 installer. can i download both, or they are the same
A driver allows the device to function properly and enables support for it on your computer, so the "installer" that you are talking about is the same thing. You can download the latest drivers from here.
Jul 03, 2011 | Computers & Internet
My hp D2460 inkjet printer never stop blinking and not printing
Time to change the ink cartridges
Or check for any paper jam
and wether the carriage is moving perfectly
if everything above is OK
its time to get a new printer....
Feb 21, 2011 | HP Deskjet 2460 InkJet Printer
Hi, I'm Cecily, and my printer isnt working at all. It says "E" beside the third button down, and an orange light won't stop blinking. I dont know what to do!
It has an Error "E" that's why its blinking orange, Turn it off, check if there's any paper jam inside it, make sure that it has ink and not used up after checking for paper jams and Ink level, remove all paper, make sure nothing is stuck inside it, reseat paper back, make sure ink catridges are reated as they should, close it, then plug it in and turn it on and verify if you still have "E" or blinking.
Dec 03, 2010 | HP Deskjet F335 All-In-One InkJet Printer
I need a driver for hp deskjet d2460
You can download the software here:
deskjet-d2460-printer-driver/">http://www.soft82.com/get/download/windows/hp-deskjet-d2460-printer-driver/
Once on the page your download should start immediately :-)
That will get you back printing
Oct 02, 2008 | Computers & Internet
Hp deskjet d2460
Dear ROSE,
You can download the driver for your HP Deskjet D2460 , from this site :
http://download.famouswhy.com/hp_deskjet_d2460_printer_driver/free_download.html
Be Happy always.
Regards
Sep 15, 2008 | HP Deskjet 2460 InkJet Printer
Halftone printing
do you mean grayscale printing?just configure your printer setting to print in grayscale using the black ink only..HP D2460 is capable of printing using only one (1) installed cartridge..
Jul 01, 2008 | HP Deskjet 2460 InkJet Printer
Printer not working
my hp 2300jet ink printer not taking paper,green light only blinking
Mar 10, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP DESKJET 2460
Hi, Not sure what your operating system was so here is the link to the page with all the software for your printer. Just choose your operating system and continue to follow the links.
Link Is:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2510767&lc=en&cc=au&dlc=en&submit.y=6&submit.x=6&lang=en&cc=au
Let me know how you go.
SeaJade
Nov 21, 2007 | HP Deskjet 2460 InkJet Printer
HP Deskjet 2460 InkJet Printer Logo
10,012 people viewed this question
Seeker5211
Seeker5211
