Question about Kenmore KBC12 Coffee Maker
Filter replacement the front of my coffee maker says replace filter and clean I dont know how
  • ladykay1990 Jan 24, 2009
    Please help..I am trying to replace the filter the Kenmore coffee maker says i need to replace the filter. Model number is 100816667OA
Google DCC-RWF, the manufacturer model number for the filter, and you will get a number if sites that have it in stock
Posted on Feb 01, 2009
Keurig reservoir lite still blinking after water added
Make certain the container is flush with the body of the coffee maker. Press it in tight and if that fails, the contacts may be coated or need repair. Clean with vinegar as stated in the manual to clear deposits. Average...replace filter 3 Mo. Clean 6 weeks depending on Hard or Soft water conditions.
Jan 22, 2014 | Keurig Platinum B70 Coffee Maker
I have a Keurig B60 coffe maker and when i make coffee it seems to leak out the sides such that that coffee is not directly coming out the bottom holes. I have cleaned the bottome holes to ensure...
Hi, Yes, you are missing the gasket around the top needle...
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
Sep 20, 2011 | Keurig B70 Coffee Maker
Only a few drops of coffee come out
Hi. that filter must be replaced regularly. you can order replacements here
Aug 01, 2010 | Keurig B60 Coffee Maker
Foul-smelling coffee
you may need to run white vinegar thru the unit... and dont be in a rush to get the vinegar out of it... let the vinegar work...
If you suspect bacteria, then mild bleach water... and dont be bashful about the quantity... allways filter the water and consider using bleachwater to clean the needles that puncture the kcups....
May 03, 2010 | Keurig Special Edition B60 Coffee Maker
I need to know how to clean my ge coffee maker model 169165, the clean light has been on a while and it has become significantly slower in brewing
Remove the carbon filter. Place a solution of 1/2 water, 1/2 vinegar into the machine. Hold down the cleaning button for 3 seconds. Cleaning cycles on and off for 1 hour. After complete, run 1/2 pot of fresh tap water through. Replace carbon filter with a new one. This should do it!
Jan 16, 2010 | GE 106591 Coffee Maker
Need a replacement filter and cannot find one
Original BS filters are still sold on Amazon (search Bodum Santos Replacement Filter) and they are found regularly on ebay. The filter was never the greatest for preventing sediment - but sediment is what you learn to love, more or less, with vacuum pots and presses.
Not a seamstress, I have still managed to hand-stitch a few excellent filters from 100% canton cotton for my older vacpots. Assuming you have the filter hardware, woven cotton and some shirred elastic makes an excellent filter for vacuum pots. Clean/rinse after use and store in a glass of water in the fridge between uses.
Brew on.
May 19, 2009 | Bodum Santos 3000 Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Stay and Go coffee maker just quit during cleaning
Hang on. Wait until it has cooled and dried. Mine did this. About a week later, I tried it... Display was incredibly faint. But after some use, it "came back." Same as new. Everything is working.
Just... don't give up on it yet.
Feb 01, 2009 | Hamilton Beach Stay or Go 45234 Coffee...
GE 169164 coffee maker problem
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Aug 01, 2008 | GE 106591 Coffee Maker
Kenmore KBC12 Coffee Maker Logo
201 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
Steven Clarke
Steven Clarke
ray gallant
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
