Question about Nuova Simonelli Premier Maxi Espresso Machine
Doesnt work when its warm
I have a used premier nuova simonelli with 2 groups and after I make 3or 4 drinks the pump is unable to pump water in. I can hear it trying but the machine wont let the water in. It only works again after I turn it off for 20 minutes and when it cools off I can turn it on and it works perfecty for 3 or 4 more drinks. Any ideas on what is wrong?
The pumps in these are low resolution pumps and don't seem to take a lot of stress. We ran the same machine with three groups 362 days a year. You probably need to replace the pump. You should watch your gauges and be pulling 9 - 10 bars when pulling a shot. The top side of your gauges is water pressure coming in. Sounds like a new pump. Good luck.
Posted on Feb 12, 2009
How do you manually fill the boiler tank of a Nuova Simonelli Premier Maxi 2 Group?
by opening the bypass valve under the tray need the drain. but certainly you have a problem with either pump motor or volumetric pump
Apr 14, 2016 | Nuova Simonelli Premier Maxi Espresso...
Nuova simonelli manual switch flashes
it means that no water is flowing on the flowmeters. need to check flowmeters if clogged
Jun 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Nuova Simonelli Premier Maxi V , 2005...when water turned on machine constantly leaking from the pressure relief valve and the hot water valve.
Has the machine been in cold storage? If no then the inlet solenoid could be the culprit. There might be sediment keeping the valve open.
May 11, 2011 | Nuova Simonelli Premier Maxi Espresso...
I have a 3 group 2002 premier maxi. the laft and
The metering jet filter on top of the heads are blocked or the solenoid coil is damaged.
Jun 18, 2010 | Nuova Simonelli Premier Maxi Espresso...
Pump runs for a minute - stops and water light
Make sure that the inlet solenoid is not blocked, the manual fill might be fine but the solenoid could be blocked.
Nov 01, 2009 | Nuova Simonelli Premier Maxi Espresso...
Nuova simonelli mac cup red light
It sounds like the thermostat on the boiler nest to the element tripped. Fill machine with water until you can see the level about half way, then open the right side of the espresso machine, you might be able to get to thermostat from the top of machine (make sure it is unplugged) then press the red pin on the boiler between the 2 wires, that should reset the thermostat, if it does not then it will need to be replaced. As for the water on the top of the group head, is there any way you can post a pic of the top, because simonelli made a few different head and I want to give you the correct advise.
Nov 13, 2008 | Nuova Simonelli Premier Maxi Espresso...
Nuova Simonelli Premier Maxi Espresso Machine Logo
175 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Eric Ramos
Eric Ramos
Tom Chichester
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
