Washer is leaking around bottom of the drum.
Washer started leaking from bottom of drum. I took off the agitator and inner drum off and found a bolt was broken from the plate/ lock. I put a new bolt on and its still leaking. I assume there is a seal or a bearing that needs replaced. I have no clue how hard this would be or what seal it might be. Frigidaire Gallery GLWS1749FSO
  • brianstaylor Nov 14, 2008
    So does just the seal need to be replaced or the bearing as well? Its worth a shot to try to fix it if the parts aren't that expensive. I will never buy a Frigidaire again or this model. Its only two years old and we've had to have repair men in twice! Any recommendations on a good brand of washing machine?
    I've checked and they do come seperate as well. I'll let you know how it turns out and thank you so much for your help!
    Scholar:
  • 66 Answers
Yes, this does sound like the seal is bad. Unless you have replaced the bearing and seal in one of these bafore. It can be very dificult, without expierence. If not replaced correctly, it can still leak or can cause other problems.
Posted on Nov 14, 2008
  • Charles Caldwell Nov 14, 2008
    The bearing and seal come together as a kit and they should both be replaced at the same time. If I can help you with anything else I will.
    As far as price. They do not tend to be too expenive but you will have to check with supply places in your area to get a better idea of your price. The price varies with supplier. Most of the time the seal and bearing come together as akit.
How do you remove inner drum on top loading LG Washer WT5170HV?
The whole top of machine must be removed.
unplug electronics and hoses remove upper splash ring remove cap in center of agitator remove bolt holding down remove .
remove inner tub Nut center tube should lift up and out.
next step if your changing shaft is all from bottom.
lot more down there. Take picture b4 and as you remove for ref. to resemble
Jul 03, 2016 | LG Wave WT5170HV 27" Top-Load Washer with...
Burnt smell bits of plastic found inside
A WM1814CW does not have a built-in water heater, so I think your
load may have gotten trapped between the spinning tub and plastic
front tub cover..Roll back the gray gasket to expose and check the
plastic ring for signs of 'friction' burn..As long as the splinters are
trimmed away and doesn't leak water you should be OK..Watch your
loads..Don't Overload!
Aug 18, 2014 | LG WM1814CW Front Load Washer
Water leaking out of bottom of machine, nothing clogged and found a bolt head in tub
if you found the bold head in the tub chance are that the trunion bolt has broken off and cause the tub to become unsecure from the agistatir shaft and has torn the seal below the inner tub. remove the agitator and you will see the trunion and two bolts.the tub ring has to be removed and then the inner tub has to come out in order to replace tub seal.the tub seal part number is 5303279394 it cost around 45 dollars. the screws need for the locking plate are 131192800 and they caost about 4 dollars a piece.i hope this has helped you out.let me know how things go and if you need any more help let me know.
Jan 22, 2010 | Frigidaire FWSB5700DS Top Load Washer
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
Admiral washer lnc6160b71
If you mean the inner drum - remove the agitator, pull off the sofetener cup and remove the 15mm bolt down inside to remove agitator, then secure inner drum to center bearing.
If you mean the outer drum, check the holding down springs visually, remove the front panel by inserting a flat blade approx 4" from each side at the front to release clips, then remove 2 small bolts to remove front panel.
Also check and replace drive belt, tilt machine backwards to gain access underneath.
Jul 15, 2008 | Admiral AW22 Top Load Washer
Zanussi ZJ1217 loud rumble on spin
hiya m8 u need to take the lid off undue the first 2bolts on each side undue the bolts at the back and finally pull the plugs out off each side base and there will be a bolt undnerneath the plug now the complete back will come away letting u into the washer inners now u will have to undue the door seal from the front panel.Now there is a spring on each side at the top where u took the bolts from when u took the top off u will need a flat screw-driver to pop these out undue the electrical plugs from the motor,pump and anything else because u need to lift the drum completely out now undue all the bolts that go around the drum releasing both sides of the drum.Pull them apart now u need to undue the big bolt that holds the spider wheel on the back side of the drum place both hands on either side of this wheel and pull side to side until it pops off now u can pull the inner metal drum out u might need to hammer it a little with a rubber mallet once uve pulled it out u can get to the bearings one is behind a rubber seal these will need to be chiseled out this will be a hard job but sometimes u get lucky and they come out easy now to re-place them u will need some debor glue witch u can get from ebay and some metal red glue cant remember what its called at this time but u will get were u get the debor glue from put the metal glue around the outside of the bearings and make sure u do not get it on the inner bearing this will mess the bearings up now once the bearing kit is in u will need to put the debor glue all around the black rubber seal on both sides off this seal and place the inner drum back in tighten the spider back up and put both sides off the outer drum together again now tighten the bolts up again which go all the way around to fix outer drum together but 1st bolt should be then followed by the opposite bolt dont do the bolts up right next to each other because this will worp the drum slightly and it will leak now just put it all back together dont use for at least 3hours let all the glue that u have used go off this will stop it leaking at all this should take u at most 3hours to do an engineer will do it in half-hour this is the longest advice ive given ever so hope it goes well and happy fixing m8 let me know how u go on print this of it will be easier to follow next to u m8 peter
Jun 08, 2008 | Zanussi ZJ1217 Front Load Washer
Worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Apr 14, 2008 | Frigidaire FWS1339A Top Load Washer
LEAKS AND SQUEAKS
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Mar 24, 2008 | Maytag PAV2300 Top Load Washer
Washer spin when in wash cycle
the problem is specifically the motor tacho which consists of a rotating magnet screwed to the motor shaft and a fixed coil around the magnet. the problem can be the magnet unscrewed or the coil fallen out.either way, they can usually be repaired by glue or packing.
Nov 07, 2006 | Zanussi FJ1454W Front Load Washer
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
