Question about Dishwashers
Kenmore dish washer wont drain
My kenmore dish washer wont rain all the way. I found 2 hard plastic balls floating around when I took it apart. They look like check valves and now I dont know where they go
Those are Chinese massage balls. You place them in your palm and rub them together and the result is a "calming" effect, which are ingeniously placed their by the courteous engineers at Kenmore to help you relax while you perform the self-repair. Just kidding. I had the same problem and learned that they are called "float balls". There should a small hole where the water comes up and drains - they are placed in that hole.
Posted on Nov 27, 2008
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
My Kenmore Elite washer starting making a bad noise during rinse/spin cycle and now wont drain??
Most washers have a gearbox that has about 15 gears in them it's the heart of the whole process backwards fast slow is all controlled by these gears my whirlpool box was off white took total dis assembly would cost more to fix than replace... so I opened box the hard way and found millions of tiny perfect .5mm cylinders as if from penny's and nickles over the years cool to lok at but devastating on plastic gears....be prepared to go used washer shopping...~~~SC
Sep 25, 2014 | Washing Machines
My kenmore HE2 wont drain.
Hi there I suggest that some machines have that white ball to stop water from syphoning out of the machine when on a wash cycle but your problem is either a blocked pump, (try and take the pump off as some debris will go past the filter and stop the impeller from turning hence no water being pumped out) or a kinked outlet hose which can easily happen when you push the machine back into it's place in the kitchen.
I'm not too conversant with your make of machine but in general all machines are basically the same.
If you can't hear the pump spinning then it may be something more like one of the circuit boards may have failed.
Mar 11, 2014 | Kenmore HE2 Plus Front Load Washer
Washer stopped. F6 code, didn't drain.
that is called an eco ball it is part off the machine
its job is to save money by not heating the water below it in the drain pipe
Dec 29, 2013 | Kenmore 46462 Front Load Washer
Took apart to clean because it would not drain. 2 plastic balls popped up from who knows where. where do they go ?
hi if these balls apeard when you took the pump apart they may be part of the anti syphon device.****
Dec 02, 2010 | Kenmore Dishwashers
Our dishwasher will not drain. We took the drain hose off, it is clear. So we dismanteled the botton thing in side the washer. Cleaned all the lime disposits and other ****. There were two little bead...
Pull out your dishwasher
Lean backward about 45 degrees
A small amount of water is coming out
put your appliance at its original position
Now it will be working
(normally there is a floating valve under the bottom of your appliance which has been stacked and sends the signal of no water flow.)
In case that it does not function, then there is a hard work to clean the plastic "labyrinth" which normally is fixed at the left side panel where a floating valve has been stacked a cause of dirty material.
Jul 29, 2017 | Kenmore 24 in. 17012 Built-in Dishwasher
Kenmore model 665.17609300 type 575-0 Dishwasher will not drain. Float valve and drain solenoid ohm out correctly. Drain hose is clear. Suggestions?
Check your air gap on your drain. It should be located on or around your sink. Sometimes food and other trash will stop it up and will not let your dish washer drain. The cap should unscrew off .Good Luck.
Aug 13, 2009 | Kenmore Dishwashers
Dishwasher will not drain completely
dishwasher will not drain.kenmore model.
I have taken it apart can not figure our how to take out last plastic part a bowl shaped black plastic.
Mar 22, 2009 | Jenn-Air 24 in. JDB1250 Built-in...
Kenmore Elite flashing codes.
ob means out of balance and ld means lid not closed. so i would guess that you have a washer that is not draining or just needs the clothes moved around.
if you have a plugged pump it will do the same thing. make sure the pump will drain properly and then try it again. if it still goes out then try it with no clothes. that way you know its not hte clothes causing the problem.
recheck the pump and hoses. be sure it will drain the full tub or it wont work right.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 41729042990 Front loading washing machine
you can take the pump apart by removing the 3 screws that hold it together. take it apart to make sure there nothing in it that could be blocking the impellar. if theres nothing in there, replace the pump
Nov 26, 2007 | Kenmore 44042 Front Load Washer
Dishwashers Logo
272 people viewed this question
Top Dishwashers Experts
